Shift Register
A shift register is used for serial input and parallel output. The arduno has limitations of input/output pins,with the help of shift register output pins can be increased
Supplies:
Given below
Teacher Notes
Step 1: COMPONENTS REQUIRED
×8 (1K-resistors)
×1(74HC595)
×1(arduno uno)
×19(male wires)
Step 2: Main CODE
const int DataPin= 2;
const int clockPin= 3;
const int LatchPin= 4;
could setup( )
pinMode(DataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(LatchPin,OUTPUT);
voild loop( )
digitalWrite(LatchPin, LOW);
shutout(DataPin, clockPin, LSBFIRST , 255 );
digitalWrite (LatchPin, HIGH);
delay(1000);
shiftout(DataPin, clockPin, LSBFIRST, 0);
digitalWrite (LatchPin ,HIGH);
delay(1000);
Step 3: SCHEMATICS
Digital pins =4, 3,2
Negative pin= gnd
Positive pin= +5
Step 4: TROUBLE Shooting
Showing wrong pattern : try changing LSBFIRST/HSBFIRST in shutout command
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    Shraddhajoshi
    Tip 6 weeks ago
    Polarity of COMPONENTS matters
