Shock Absorption Metal Robot Car Chassis for Arduino Raspberry
About: Specializing in the OpenSource Hardware. skype: yichone
Product Parameters:
Name: Shock Absorption robot tank chassis TS100
Material: aluminum alloy
Surface treatment: sandblasting oxidation
Motor: 9V 150rpm with encoderColor: black
Wheel: metal
Track: engineering plastic
Product size: 270*255*90mm(L*W*H)
Weight: 1100g
Maximum load: 5kg
Package included:1*robot tank chassis TS100
Free sent:18650 battery box
Acrylic Plate
Couplings
now can be got at amazon:USA, UK, DOIT Shop
the full assembling document can be downloaded at our wiki: wiki.doit.am
Step 1: Installation for Bearing Wheel (one TS100 Needs 10pcs Bearing Wheel)
a) material for one bearing wheel:
1)17mm copper pillar: 3pcs
2)M3*8 screw: 6pcs
3)stainless steel connector: 1pcs
4)M2 screw: 1pcs
5)cup bearing: 2pcs
6)wheel piece: 2pcs (note: when install the wheel, please let the location hole is aligned with each other)
Step 2: Install the Shock Suspension (the Total Is 8pcs, Including Left and Right 4pcs)
a) Materials when install a shock suspension:
1)installed bearing wheel: 1pcs
2)shock suspension bracket: 1pcs
3)cup bearing: 1pcs
4)M4*8 screw: 2pcs
5)M4 screw nut: 1pcs
6)spring: 1pcs
Step 3: Install the Side Plate
use
M4*8 screw and nut to fix on the side plate, shown in the following picture
Step 4: Installation a Bearing Wheel to the Side Plate (left and Right)
The wheel can adjust the length of track.
a) Material when install a bearing wheel
1)bearing wheel: 1pcs
2)16mm gasket: 2pcs
3)M4 screw: 1pcs
b) leave enough space to adjust the track when install this bearing wheel to the side plate
Step 5: Summary
a) materails
1) metal panel: 1pcs
2) left and right installed side plate with bearing wheel
3) installed driving wheel: 2pcs
4) motor: 2pcs
5) track: 2pcs
6) M3*12 screw: 8pcs
7) M3 nut: 8pcs
8) M3*10 screw: 4pcs
    • Faux-Real Contest
      Faux-Real Contest
    • Warm and Fuzzy Contest
    • Safe and Secure Challenge
