Shrimping Helper
Introduction: Shrimping Helper
Shrimping, also known as 釣蝦 in Chinese, is one of the most unique and popular hobby for Taiwanese. Lots of Taiwanese go to shrimping in weekends. From enjoying the fight with the shrimps and eating the shrimps, shrimping is definitely one of the best weekend activity. Nonetheless, there has always been an annoying problem, counting shrimps and looking at the remaining time. After shrimping, people have to go to the fountain and count their result one by one, which is extremely time-wasting and ineffective. For the latter, always looking at the receipt with start time and then calculate the remaining time by looking at a phone for the current time is definitely irritating. Therefore, I plan and build this device to solve the problems mentioned above, specially designed for shrimping.
Supplies:
Before Starting, Prepare:
1. Arduino Leonardo
2. Breadboard
3. Computer with Arduino IDE
4. Micro USB Cable
5. Powerbank
6. Switch
7. LCD I2C
8. Ultrasonic Sensor
9. Wire
10. Cardboard Box
11. Resistor
Step 1: Connecting the Circuits
Arduino:
Digital
D5 -> Ultrasonic Sensor Trig
D6 -> Ultrasonic Sensor Echo
D9 -> Switch
SDA -> LCD I2C SDA
SCL -> LCD I2C SCL
Power
5V -> Breadboard Positive
GND -> Breadboard Negative
USB
Micro-USB -> Powerbank
Step 2: Circuit on Breadboard
Positive:
Arduino Power 5V
Switch
LCD VCC
Ultrasonic Sensor VCC
Negative:
Arduino Power GND
Switch
LCD GND
Ultrasonic Sensor GND
Connect LCD and Ultrasonic Sensor according to labels on them
Connect Switch as Image
Step 3: Coding
Code is in the file attached.
Step 4: Designing the Appearance
I used a cardboard box to put everything of the device in, including Arduino, the breadboard, all the other parts, and the Powerbank. Then, I made some holes for the sensors and LCD to be shown outside of the box. Use a knife to make two round holes on the top of the device for the ultrasonic sensor. Next, I made a hole at the side of the cardboard box for the switch to come out from the box. Lastly, I made a rectangle shaped hole in the front of the device so the user can see the information.
Step 5: Done!
Then, you have finished this device. You can then take this to shrimping, and stop getting annoyed from those irritating problems. Happy Shrimping, and hope you can get some lot of shrimps! 祝你天天爆籠
Step 6: Using the Device
1. Turn on the Device
2. In 10 seconds, press the button for as many time you are shrimping(in hour). The second row of the LCD should show how many hours as you press the button. Ex: 3 hr equals to pressing the button three times
3. Start Shrimping, and place the device on your shrimp net as the picture(蝦網)
4. Every time when you get a shrimp, detach the hook. Then, when you are putting the shrimp into the net, remember to let either your shrimp or your hand to go over the ultrasonic sensor so the device will count the shrimp. Don't worry for the sensor sensing repeatedly when there is only one shrimp because the sensor won't sense the next signal until the next minute.
5. Shrimp happily!!
6. When the time reaches 0:0, remember to stop shrimping and give the receipt back to the owner of the shrimping place. And be a good shrimper!
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    2 Discussions
    Jobar007
    Jobar007
    1 year ago
    I found out about shrimping around 3 years ago. It seems like it would be so much fun. I'm glad to see some people bringing ideas to the table to help make it more enjoyable.
    I really like your idea and design. The hands free counting of the shrimp is a good touch. My only suggestion would be a water proof container for your next version of the Shrimping Helper.
