Side Table (2x4 Project)
I am going to be teaching you how to make a modern side table with step-by-step instructions. The goal of this project was to make the best item made by more than 1 and less than 2 2x4s, this project has to be 80% wood.
Supplies:
2 - wood 2x4
4 - nails
Masking tape
F style clamps
Tools needed:
Table saw
Miter saw
Hand sander
Drill
Planer
Teacher Notes
Step 1: Cut Out Pieces
Cut out 12 pieces at 12" length with 30 degree angles at the end of each side making a trapizoid. Make sure after every cut on the miter saw you flip the 2x4 so that both of the angles are facing outwards. Afterwards use the table saw in order to make sure all the angles you cut are the same(Make sure to do both sides).
Step 2: Sand
Sand all twelve pieces in order to make sure they are smooth. Do this by using a hand sander.
Step 3: Glue
Take the twelve pieces and glue them into triangles, 4 triangles with 3 pieces each. Make sure they are clamped together, I used masking tape and taped at the edges.
Step 4: Glue Together
Take the 4 triangle pieces you glued together and glue them stacked on top of each other, use F style clamps to hold it together.
Step 5: Straighten Edges
Use the planer and straighten each edge of the triangle you glued together on the last step. Then sand with a hand sander.
Step 6: Cut the Legs
Cut the rest of your last 2x4 in half width ways. Then cut 4 pieces that are 15" with a 60 degree on one end of each piece.
Step 7: Sand
Sand the 60 degree angle on each leg with a disc sander and the rest of the leg with a hand sander
Step 8: Glue Legs
Take the legs you cut and flip the triangle upside down and glue the 2 legs on each side 8" from the top of it leaving the top side without legs. Drill in nails in each leg in order to help clamp them.
Be the First to Share
    • Made with Math Contest
    • Cardboard Speed Challenge
    • Multi-Discipline Contest
    2 Discussions
    Alex in NZ
    22 days ago
    That looks like a pretty robust and solid table. Well done, and thanks for sharing your idea :-)
    audreyobscura
    22 days ago
    Thanks for sharing your 2x4 project! Always love seeing stuff like this on Instructables!
