Silhouette Cameo 4 Crooked Cutting Repair
Introduction: Silhouette Cameo 4 Crooked Cutting Repair
About: Technical department of Hexis Nederland For Silhouette and Graphtec
When your cuts are not the way they should be probably there is a screw not tight enough inside the Cameo 4.
When you follow the next steps this issue should be over.
Good luck
Teacher Notes
Step 1: Take Your Cameo 4 on a Flat Clean Suface.
Step 2: Unscrewing
Turning the Cameo over and remove the 2 screws as shown on the picture.
Step 3: Remove Cross Cutter
Remove the cutter unit and turn the Cameo back facing you.
Step 4: Again 2 Screws
Remove the 2 screws as shown on this picture
Step 5: Open Cover
Gently slide cover to the left side away from the Cameo
Step 6: Screwing
When you look inside the machine from the backside you see a wheel which moves the under axel.
when you turn it you see 1 screw (See picture) Tighten this screw and reverse follow the steps and plug the machine back in.
Happy Crafting.
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
