Silver Salmon Bobber Set-Up
Introduction: Silver Salmon Bobber Set-Up
Materials:
- Torpedo floats
- Size 5 or 7 barrel swivel
- 15lb monofilament or fluorocarbon leader line
- 2/0 barbed hooks
- Size 7 split shot
- Bobber stop
- Two 8mm beads
- Cured roe
Teacher Notes
Step 1: ​Preparation
To determine the overall length of your set-up, you need to know how deep the water is where you are fishing, most silvers swim in 3.5 to 4 feet. You want your roe to float about 6 inches from the bottom. Once you determine the depth, you can fix your set-up. For this, we have predetermined the depth to be 4 feet.
Step 2: Bobber Stop
Take the bobber stop. Affix the stop onto the mainline (for mainline I use 30lb Berkley FireLine, so it about 3-3½ feet from your hook when complete.
Step 3: Bobber
Once the stop is fixed, line your float, with the colorful end towards the bobber stop. Place one bead above your float and one below.
Step 4: Swivel
Use a cinch knot to tie your swivel.
Step 5: Hook and Leader
The total length of your leader line should be 18 inches. When you cut the desired length, make sure to account for extra line needed to tie the hook on.
Take one 2/0 hook and tie it to the end of your leader using an egg-loop knot.
a. If regulation allow, you can create a drop rig where you tie on a trail hook with the same knot about two inches below your first hook.
b. If you don’t know how to tie an egg-loop knot, just buy a pre-tied hook that's 15-20# test and 2/0 hook.
Using a cinch knot, tie the end opposite the hook to the swivel.
*Optional Step* If you decide to use a corkie/spin-n-glo/cheater slide it down the leader so it sits above the hook, allowing it to free slide.
Step 6: Split Shot
Take one split shot and clamp it 6 inches below the swivel. Take a second split shot and clamp it 12 inches below the swivel (they each should be 6 inches from each end)
Step 7: Roe
Take a half-dollar amount of roe and place it in the egg-loop, and cinch until it holds firm.
Step 8: Final Product
And now you’re ready to go fishing!
Be the First to Share
    • First Time Author Contest
    • Space Challenge
      Space Challenge
    • 3D Printed Contest
      3D Printed Contest
    2 Discussions
    mr.green
    mr.green
    1 year ago on Step 8
    This is a great rig. I use a very similar style and have caught many trout with it. Very good instructable
    Great introductory fishing tutorial. Thanks for sharing it with the community.
