Simple Adapter From Bulb Light E27 to Socket
716
Hello!
Have you ever had a situation when you need a socket, and nearby, from sources of electricity, there is only a light bulb. And here I was in this situation. So I decided to make an adapter from the bulb holder E27 to the socket.
Teacher Notes
Step 1:
Took a led light bulb and old light socket. First of all, I disassemble the light bulb.
Step 2:
I disassemble the socket and disconnect the metal frame of the socket.
Step 3:
I try to insert the socket into the body of the bulb.
Step 4:
The socket didn't fit. I take scissors on metal and cut off all superfluous. Then I take the light bulb, put it to the cover of the socket and circle the contour of the bulb. Used an awl.
Step 5:
I cut off everything superfluous with Scissors.
Step 6:
I drill the base of the bulb. Solder the wire to a larger cross-section.
Step 7:
With the help of thermal glue, I fix the socket in the body of the bulb.
Step 8:
I fasten the cover from the socket. I sand the contour of the edge with sandpaper
Step 9:
–°hecking how it works
Step 10:
While I was making this outlet, I came up with another version of this adapter. It is more convenient to use and, most importantly, you will have a light source.
Again disassemble the bulb.
Step 11:
I check how the contacts are located.
Step 12:
To get to the bottom contact, I drilled the base of the bulb.
Step 13:
I make a hole in the ceiling of the bulb and stretch the wire.
Step 14:
I insert and solder the wires to the contacts of the bulb
Step 15:
I removed the excess solder on the bottom contact of the bulb.
Step 16:
With scissors on the metal, I make a small notch.
Step 17:
Checking how it works
Step 18:
Both options have the right to life, but I liked the second option more. It is more functional, you still have the light source, you can on/off the instrument with the network filter button.
I agree that in everyday life such homemade products are not useful, but in an emergency very useful.
Thanks for your attention.
Make it Glow Contest
This is an entry in the
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    2 Discussions
    Stan1y
    3 days ago
    As lighting circuits are not rated for as high a current as power ones this could do with incorporating a fuse or reset-able thermal contact breaker (5amp would do for UK but not sure about European /US regs) or you risk knocking out the lights in the whole building. Somewhere I've got a commercially made version from the 1940s/50s of this for a bayonet style fitting there sale was banned as they caused/ got blamed for too many fires
