Simple Alcohol Powered Bottle Rockets
Introduction: Simple Alcohol Powered Bottle Rockets
About: a teenager eagerly doing all fun DIY projects that I can do now because now I have TIME, FREEDOM, and couple of bucks when I need them. will appreciate suggestions from experts when they think I need them.
Simple and Easy Bottle Rockets.
Be Sure to watch this video by which the Idea came about: http://zipansion.com/1G6cM
SHOW MORE
Teacher Notes
Step 1: Putting It Together.
Firstly grab a stove igniter and attach a small pipe to it's hose the width of which should be just as much as the bottle neck.Cut a Bottle like a funnel and attach that as well.
Warning:You must attach the Funnel(ed) Bottle to make sure the heat is kept away from your hands as otherwise you may burn your hand
Use duct tape to firmly secure everything in place and you are ready to go!
Step 2: Firing the Bottles
Add a few milliliters of Spirit/Rubbing Alcohol and then cap the bottle then shake to Evaporate the Alcohol. Uncap the bottle and pour the alcohol back into the bottle you took it from.Jerk the Bottle to remove droplets of Spirit and then Squeeze the Bottle to remove excess alcohol droplets and introduce some Oxygen into the Bottle.
Attach the Bottle to Launcher and take aim!
Be the First to Share
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
