Introduction: Simple Cobra Knot or Weave
Step 1: You'll Need
• any color of paracord
• lighter
• scissors (to cut your cord and the excess cord)
Step 2: First
Lay out the cord straight
Step 3: Second
Make a big loop from the middle and keep the other cords straight
Step 4:
Then your going to take the left string and lay it over the loop keeping a little loop
Step 5:
So by now it should look like this
Step 6:
Next take the right string and lay it over the string you just put over the loop
Step 7:
Next your putting that string UNDER the big loop
Step 8:
Make sure it stays under the big loop
Step 9:
So now it is under the big loop
Step 10:
After you put that string under the big loop put it through the bottom of the small loop
Step 11:
Then tighten but do it carefully and keep the big loop pretty big
Step 12:
Then tighten till your happy
Step 13:
And it should look like this
Step 14:
Now take the right string and set it over the big loop
Step 15:
Now set the left string over the string you just put over the loop
Step 16:
Then put that string UNDER the big loop
Step 17:
And take that same string and put it through the bottom of the small loop and carefully tighten
Step 18:
Step 19:
Your going o do this multiple times till the loop on the very bottom is pretty small
Step 20:
Step 21:
Step 22:
Step 23:
Then when your happy with it pick up your scissors
Step 24:
Cut of the excess string pretty close to whole thing
Step 25:
After you cut of the string get your lighter
Step 26: Finally
And light the string just for a second until it gets warm and starts to turn clear then STOP it will catch on fire then let it cool
Step 27:
And walla after you get use to it you can do it fast and they turn out great even in the car. And you can even mix string in there to
