Simple & Easy Spider-Man Web-Shooter
About: Hello there! Emma is a 16-year-old droid builder from the USA. Her channel comprises of tutorials, project updates, and more. YouTube: https://www.youtube.com/channel/UCJF94ue1dcpTeDP_hjS0ZPg Please note: ...
Have you seen a Spider-Man movie?
A Spider-Man comic book?
Anything vaguely Spider-Man related?
Spider-Man is seemingly everywhere. Why not make a simple web-shooter? After a bit of practice, I created a design from house materials that could be created quickly. This simple Spider-Man Web-Shooter can be a toy, a party favor, or modified for a cosplay prop.
Teacher Notes
Step 1: Materials Used
Tools:
Pliers
Scissors
A long screwdriver, or a dowel
Duct Tape
Hot Glue/Super Glue
Permanent Marker
Ruler
For the Web-Shooters:
One old ballpoint pens with a clear, plastic tube
Two old pens with springs
Two rubber bands
3 Popsicle Sticks (at least)
Duct Tape
For the "Webs":
White Paper
Clear Tape
Toothpicks
White thread
Step 2: Making the Web-Shooter: the Barrel
A disassembled pen can provide a clear barrel for the web shooter. Using the pliers, pull the pen apart, using the screwdriver to push out any small pieces inside the barrel.
Step 3: Cut It
Next, cut the barrel into two 2" tubes. These will be used for two separate web-shooters, one for each hand.
Step 4: The Springs
Two other old pens can be disassembled for their springs. Two springs are needed.
Step 5: Cutting the Back of the Launcher
This step can be repeated for a second web-shooter.
Trace a popsicle stick with the edge of the barrel and cut the popsicle stick.
Step 6: Assemble the Launcher
This next step will need to be repeated for the two web-shooters.
The spring is then glued to the popsicle piece, and the barrel is immediately placed around the spring.
Step 7: The "Trigger"
Cut 1" off a popsicle stick, then reattach the two pieces with a 1"-wide piece of duct tape.
Step 8: The "Trigger" Mechanism
Cut a 1/4" piece off a popsicle stick and glue it to the edge of the tape on the longer side of the stick.
Step 9: Attach the Launcher
This step can be repeated for the second web-shooter.
Glue the launcher barrel onto the side of the popsicle stick with the barrel covered by the small popsicle stick. After it dries, roll over a rubber band to keep the barrel and the trigger taught. When the trigger popsicle stick is pressed down, the barrel is opened. When the popsicle stick is released, the rubber band brings the cover back in front of the barrel.
Step 10: Making the Webs
Cut a white piece of paper into 2” by 3” pieces.
Basic Web
Tightly wrap one of the cut pieces of paper. Wrap tape around the paper and remove the toothpick, then slide the toothpick out.
Trailing Web
First, repeat the Basic Web design. Next, tape a foot-long length of white thread onto the edge of of the "web."
Trailing Web
Repeat the Basic Web design, but ensure the toothpick is taped to the paper.
Step 11: Making the Wristbands
Cut duct tape into two 10" strips, then fold them over. Glue the strips to the Web-Shooter. Wrap the wristbands over your wrist, then use a separate piece of tape to attach them.
Test and adjust the wristband until it fits comfortably.
Step 12: Conclusion
You now have a functioning, simple web-shooter. Although it won't support you swinging around New York, the web shooter can still bring fun...launching web-darts at targets and letting webs fly around.
If you make your own, please let me know, I'd love to see! This is my first Instructable, but I plan to make more.
Toys Contest
Toys Contest
    • Indoor Lighting Contest
    • Make It Fly Challenge
    • Growing Beyond Earth Maker Contest
