Simple Function Generator
Introduction: Simple Function Generator
About: I'll be doing lots of interesting things here, but mainly :electronics (arduino, analog and digital), computers (old and new), programing (C# and python), linux (administration and hacking). Geeky enterteinm...
In my last instructable i showed you how to build pwm signal generator, and i used it to filter some other waveforms from it. In this instructable i will show you how to make simple function/frequency generator, how to drive relay with it and how blink led without arduino.
All you need is:
Teacher Notes
Step 1: Build It
Circuit is easy to build it consists of oscillator and frequency selector. The wire that sticks out can be connected to male headers near capacitors, to set the frequency
Step 2: Measure It
Output of your oscilator should look like this
Step 3: Build Filter
Filter is from my last instructable, but in this project i have soldered it on piece of perf board
Step 4: Measure Filter
Waveforms should look like this, first one is after one low pass filter, second one is after two low pass filters and last one is after one high pass filter
Step 5: 12V LED Blinker
This is example use of this project. I didn't putted resistor on the schematic. I've used it because light was too intense for my camera
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Clocks Contest
      Clocks Contest
