Simple Installation of a Parking Heater in a Campervan
Introduction: Simple Installation of a Parking Heater in a Campervan
simple to have warm parking in a van
Step 1: Few Pieces Easy to Do at Home
as few pieces as possible of aluminum and iron easy to make at home with simple tools
Step 2: Simple to Mount and Simple to Remove
it is simple to mount and simple to remove for the summer
Step 3: The Fuel Is Strictly Connect
The fuel is strictly connect near the heater so is not necessary any modification to fuel circuit of van, also it make really simple remove the complete heather also the fuel can is simply to remove for filling
I chose this installation inside the van to avoid damage of heater when go off road in mood and snow
so to run it need only two hole in the floor of the van not any work is make on the car
Step 4: Control Box
the control box is make by use a box for electronics and a switch to connect to 12V a switch to power a auxiliary fan and the control panel of the heater
I install also a digital voltmeter to check the voltage of the battery during the warm up of the lighter (need 10 A)
and a aluminum support to take the box near the heater so it is really easy to remove only by 2 screw and easy to test
Step 5: Exhaust Must Go Out With Out Risk Hole in In the Floor
Make just a small hole for exhaust pipe intake air in inside vehicle (must open a window when run the heather)
Step 6: Warm Pparking
it work really good for gold night
Step 7:
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    6 Discussions
    dougbyte
    dougbyte
    1 year ago
    I would be concerned about traveling with the gas container inside the vehicle.
    paolobertoncin
    paolobertoncin
    Reply 6 months ago
    Right but the small PVC container for diesel not gas is permitted in Italy I feel it when go to camping
    paolobertoncin
    paolobertoncin
    Reply 1 year ago
    Is Diesel not gasoline the canister is the right for diesel carry
    jprussack
    jprussack
    Question 1 year ago
    Why not just have a flexible vent that goes out the window? Yes, with this setup it's a good idea to have a window open... if you want to avoid carbon monoxide... The setup looks good but does it provide enough heat of offset an open window?
    paolobertoncin
    paolobertoncin
    Reply 6 months ago
    Absolutely right I use it only with open window and nerver use it when I sleep
    paolobertoncin
    paolobertoncin
    1 year ago
    right the exaust is go out by hole in the floor
    Always I run the heather ever with an open window!!!
    In summer in montain camps the heather is really enough
    Paolo
