Simple LED Flasher Using Transistor | Simple Flashing Led | Flashing Led
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today in this video tutorial i am going to show you Step By Step
How to make simple led flasher using transistor
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
❖ Please Subscribe / Like Facebook Page ❖
https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
https://www.facebook.com/Circuit-DIY-122206971927...
You Will Find Full Project Description and All Useful Material Including
• Circuit Diagram / Schematic
• Hardware / Component List
• Code
• Datasheet
• Pin Configuration Etc
AT ► https://circuit-diy.com/simple-led-flasher-using-...
Thanks for Watching It.
↪ For Any Difficulty Please Comment Below
Step 1: Useful Material
❖ Hardware Required ❖
► 9V Battery with Clip
► Breadboard
► Jumper Wires
► BC547 transistor
► 2N3906 transistor
► 22 ohm resistor
► 1k ohm resistor
► 1M ohm resistor
► 2.2uf capacitor
► LED
❖ Circuit Diagram ❖
Link ► https://www.file-upload.com/qp2b2x1brjs9
Step 2: Useful Steps
❖ Steps ❖
STEP # 1 ( Connect transistors )
► Connect BC547 and 2n3906 transistors on breadboard
STEP # 2 ( Connect resistor #1 )
► Connect 1k ohm resistor BTW Base pin of BC547 to Collector pin of 2n3906
STEP # 3 ( Connect capacitor )
► Connect 1.2uf capacitor B/W Collector pin of BC547 to Base pin of 2n3906
STEP # 4 ( Connect wire )
► Connect wire BTW Emitter pin of 2n3906 to VCC
STEP # 5 ( Connect resistor #2 )
► Connect 1 mega ohm resistor BTW Base pin of 2N3906 to GND STEP # 6 ( Connect resistor #3)
► Connect 22 ohm resistor BTW Collector pin of BC547 and VCC
STEP # 7 ( Connect LED )
► Connect LED BTW Emitter pin of BC547 and GND
STEP # 8 ( Test)
    • Trash to Treasure
      Trash to Treasure
    • Pie Contest
      Pie Contest
    • Epilog X Contest
      Epilog X Contest
