Introduction: Simple Lithophane World Lamp
In this project I want to make a lithophane lamp
before starting, let's prepare the tools and materials first
the first of course is lithophane products, in this case I use 3d print.
Step 1: Convert Your Image to 3d Design
I use the online application http://3dp.rocks/lithophane/,
this site is used to convert images (jpg) to litophane (stl) 3d objects There are lots of tutorials on using this site, you can search for yourself on the internet.
for example I use the world as an image
download the 3d design (stl) from the site if it has been converted
Step 2: Slicer Your 3d Design
slicer is useful for converting the 3d design (STL) into a machine command (Gcode), so it can be printed by 3D print.
I use repetier host software.you can download it for free at https://www.repetier.com/
Save your gcode file after slicing 3d design (stl).
Step 3: Print Your Lithophane Using 3dprint
After completing slicing and getting the gcode file, print the file using 3dprint
Step 4: Check Your Lithophane Product
Then if you have finished printing, take the product and try to see the temporary results by directing the lithophane in front of the light, from here we can estimate the results.
Step 5: Design Your Litophane Lamp Casing
To make the casing you can use the material up to you.
in the project I use:
1. writing tool
2. ruler
3.cutter
4.lithophane products
5. Paperboard (I use food wrapping paper)
Step 6: Make Lithophane Place on Cardboard
1. Measure the large size of the lithophane product.
2. Cut the cardboard according to the size of the lithophane.
Step 7: Assemble Lithophane With Cardboard Using Duct Tape
in this step I suggest using black duct tape, so that light is maintained inside the lamp casing
Step 8: Shape Your Case Lamp
shape your case into a box, or up to you ......, you can choose according to your art.
Step 9: Put the Lamp Into the Case
You can choose yourself for lighting. You can use LEDs, neon lamp and etc.
in this project I used a light bulb for the light
Step 10: Decorate Your Lithophane Lamp
In this step I am giving fully to your artistic talent.
in my project, I only decorate using black tape for the cashing corner
Step 11: Test Your World Lithophane Lamp
turn on your lithophane lamp and enjoy the results.
In my picture, somehow it can't be seen on the camera, maybe because of the back light effect.
I photographed it in a bright room but made the lithophane results invisible. and if I focus the camera on the lithophane, then the room looks dark on the camera.
It is a pity that I cannot capture the beauty of the photo in the picture.
Step 12: Make Your Own Lithophane
You can make your own lithophane lamp. You can make romantic lights, signs, wedding gifts and others.
let's try and work
greetings from Indonesia
Make it Glow Contest 2018
