Simple Skateboard
This is what a skateboard looks like.
Teacher Notes
Step 1: The Board
The
board is 110cm long, 25cm wide and 8mm high.
Step 2: The Board Head
The
board head is 20cm long, with an included angle of 30 ° with the horizontal, and is the same board with the board body.
Step 3: ​Wheel
Wheel
diameter 6cm, bearing diameter 3cm
Step 4: Wheel Spacing
The
distance between wheels is 18cm, and the wheel shaft is fixed by two rings.
The material has strong toughness and high hardness.
Step 5: Fixing Screw
Fixed
device under the bearing rod
Five screw fixing devices,
Step 6: Auxiliary Plate
The
height of the auxiliary plate is 5mm, which can increase the distance between the wheel and the body.
As well as the roof body and wheels
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
