Simple Touch Switch Circuit | Touch Switch Using Transistor | Basic Electronics
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today in this video tutorial i am going to show you Step By Step
How to make simple touch switch circuit using transistor
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
❖ Please Subscribe / Like Facebook Page ❖
https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
https://www.facebook.com/Circuit-DIY-122206971927...
You Will Find Full Project Description and All Useful Material Including
• Circuit Diagram / Schematic
• Hardware / Component List
• Code
• Datasheet
• Pin Configuration Etc
AT ► https://circuit-diy.com/simple-touch-switch-circu...
Thanks for Watching It.
↪ For Any Difficulty Please Comment Below
Step 1: Useful Material
❖ Hardware Required ❖
► Metal strips/Hard copper wire x2
► 9V Battery with Clip
► Breadboard
► Jumper Wires
► BC547 transistor x2
► 270 ohm resistor
► 100k ohm resistor
► LED
❖ Circuit Diagram ❖
Link ► https://www.file-upload.com/3ypmizx8dxf4
Step 2: Useful Steps
❖ Steps ❖
STEP # 1 ( Connect Transistors and make connection )
► Connect 2 BC547 transistors on bread board
► Connect a wire BTW Base pin of transistor-1 to Emitter pin of another transistor-2
STEP # 2 ( Connect resistor #1 )
► Connect 100k ohm resistor BTW Collector pin of transistor 2 and VCC
STEP # 3 ( Connect Resistor #2, LED and wire )
► Connect 270 ohm resistor and LED on Collector pin of transistor-1
► Connect wire to Emitter pin of transistor-1 to GND
STEP # 4 ( Connect metal strips)
► Connect metal strips BTW 100k ohm resistor and at Base pin of transistor-2
STEP # 5 ( Conenct battery and Test )
► Test Circuit by touching on metal strips
    • Trash to Treasure
      Trash to Treasure
    • Remix Contest
      Remix Contest
    • Tape Contest
      Tape Contest
