Simple Wrench Ring
2,699
40
4
Introduction: Simple Wrench Ring
Two ways to make a stylish ring from a wrench
Teacher Notes
Step 1: Supplies
Small combination wrenches (size ¼in or smaller)
Steel rods of differing sizes for different size fingers
Oxyasettling torch set with number 2 welding tip
Ballping hammer
Pliers
Vice grips
Welding gloves
Striker
Pedestal grinder with wire wheel
Step 2: Setup
Use appropriate sizing rod and attach wrench with vice-grips; and pliers.
Step 3: Shaping (1st Way)
Light welding torch and heat wrench while using pliers to bend around steel rod until wrench is completely wrapped around the rod.
Step 4: Shaping (2nd Way)
Attach wrench to steel rod with vice-grip and pliers. Then use pliers to bend wrench around steel rod.
Step 5: Removing/Polishing
Once wrench is shaped to desired size remove ring from steel rod with either pliers or ball-ping hammer. Run hot wrench under water then use pedestal grinder with wire ring to polish and buff the ring.
Step 6: Finished
Once ring has been polished you can use sanding paper to polish hard to reach places.
When finished wear the ring and show off your love of tools :)
Jewelry Challenge
Jewelry Challenge
Be the First to Share
    • Tiny Speed Challenge
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    4 Discussions
    jeanniel1
    jeanniel1
    11 months ago
    And now to find small wrenches ... LOL!
    sanek760
    sanek760
    Tip 11 months ago
    Maybe its better to polish it first, and then bend? It's easier to polish flat key... And after bending you'll just have to finish it up.
    blimphead
    blimphead
    11 months ago
    great idea!!
    jessyratfink
    jessyratfink
    11 months ago
    Fantastic! They're so cute :)
