// 3D PUZZLE FURNITURE // Wall Shelf
10,853
198
16
Introduction: // 3D PUZZLE FURNITURE // Wall Shelf
About: My name is Anna-Liisa, I am a DIY woodworker and spoon carver from Berlin. Together with my partner I design solid wood puzzle furniture. We want to make sustainable, affordable and stylish furniture availab...
Disclosure: Some of the links below are affiliate links, meaning at no additional cost to you, I will earn a commission if you click through and make a purchase.
Make a simple, elegant floating wall shelf using laminated pine that you will find at your local department store.
This simple wall shelf looks like it is floating on the wall, but it's secured using keyhole brackets at the back of the shelves. It's pretty easy to make and the only tools you need are a drill/driver (or screwdriver), and a jigsaw.
Find more projects on our web page TOOLS TOGETHER
YOU WILL NEED:
3 of 1200 x 300 mm and 3 of 800 x 200 mm laminated pine for the shelves
Painting materials and supplies
2 of Keyhole brackets https://amzn.to/2tu1Fnc
and 16 mm screws https://amzn.to/2MXfCSI
TOOLS:
Drill / Driver plus assorted bits https://amzn.to/2vHVcFr
Jigsaw plus clean-cutting blade https://amzn.to/2vWOTxE
Tape measure and pencil
Camera https://amzn.to/2OQLsBpLens
Lens 1 https://amzn.to/2OQLsBpLens
Lens 2 https://amzn.to/2OQLsBpLens
Field monitor: https://amzn.to/2ONrPdr
Tripod: https://amzn.to/2Mq4vB3
Step 1: Marking the Saw Route
Cut or have cut to length the laminated pine shelves. The measures will be 3 of 800 x 200 and 3 of1200 x 300 mm. Mark the sawing route as seen on the diagrams above.
Step 2: Cut the Slots
Use a jigsaw to cut out the slots as shown in the diagrams above, and also a 40 mm long rebate for mounting the keyhole hangers at the back of [2] uprights.
GOOD TO KNOW: For perfect straight lines use a steel ruler to draw out the cut lines.
Step 3: Sanding and Checking
Before assembly, take the time to sand all the boards and cut edges nice and smooth.
Step 4:
If you are painting the horizontal boards as we did for our shelf, do this now.
Step 5: Assembling the Screws
Assemble the screws for the corroborating the shelf to the wall using a drill.
Step 6: Assembling the Shelf
Slot the uprights into the shelves. If necessary, tap gently with a rubber mallet to lock the pieces together.
Woodworking Contest
Woodworking Contest
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    16 Discussions
    luke2708
    luke2708
    2 years ago
    This is a really nice looking system i was wondering how stable it would be if it was sat on the floor rather than hung
    Yonatan24
    Yonatan24
    Reply 2 years ago
    You might be able to also screw those flat 90 degree shelf brackets behind it, it could help stop it from rocking back and forth, depending on how large you make it...
    Wood Sisters
    Wood Sisters
    Reply 2 years ago
    We thought about it too. It is OK, I mean, you can`t sit on it but it will not fall apart or something.
    luke2708
    luke2708
    Reply 2 years ago
    Cool thats wicked i'm in a rental and am not allowed to damage the walls so i would need it to sit on the floor or ontop of a chest of drawers
    Wood Sisters
    Wood Sisters
    Reply 2 years ago
    I was thinking about you and you know what, you can make it more stable when you assemble few extra walls to support it from the backwards. Or you can try adding more sides, that would do too.
    Btw, have you seen this instructable: https://www.instructables.com/id/Japanese-Bondage-Shelf/ ? This is also good for a rental apartment.
    luke2708
    luke2708
    Reply 2 years ago
    Cheers yes i had seen that and i might try that out at some point what i was looking for specifically was a square frame idea as it fits the design of my room but this in a slightly smaller size would also work well. adding a backboard is a good idea and would get rid of some of the hardboard that i have lying around, also it would hide the ugly walls. ;)
    Wood Sisters
    Wood Sisters
    Reply 2 years ago
    Don't forget to make "before" and "after" pictures! Would love to see it.
    attosa
    attosa
    2 years ago
    I really love this and am going to give it a go :)
    Wood Sisters
    Wood Sisters
    Reply 2 years ago
    Cool! Please do give it a go and share the outcome too. Would love to see it!
    Kink Jarfold
    Kink Jarfold
    2 years ago on Step 6
    You know what, you're right. This was a simple build. Nicely detailed instructions.
    KJ
    Wood Sisters
    Wood Sisters
    Reply 2 years ago
    :) Thanks for the comment.
    Wood Sisters
    Wood Sisters
    Reply 2 years ago
    Cool! Thanks! I´m glad you liked it.
    jessyratfink
    jessyratfink
    2 years ago
    Oh, these are lovely and I have all the tools! I guess I don't have any excuses now, especially since my partner's been asking for more shelves :D
    Wood Sisters
    Wood Sisters
    Reply 2 years ago
    Cool! Thanks for commenting. Please do try this project, it is very easy.
    RodolfoA30
    RodolfoA30
    Question 2 years ago
    How do you hold it on the wall? Thanks!
