Introduction: Simply&Fast R-Candy
WARNING MIXING MATERIALS CORRECTLY RESULTS IN HIGHLY EXPLOSIVE AND VOLATILE SUBSTANCE!!!
DO NOT MAKE AROUND OPEN FLAME,
HAVE PARENTAL SUPERVISION IF YOU ARE A CHILD,
PROCEED WITH CREATING SUBSTANCE IN WELL VENTILATED AREA,
TRY TO AVOID INHALATION,
ALWAYS HAVE GOGGLES AND GLOVES ON HAND,
WATCH OUT FOR PAN, WHEN USED IT IS VERY HOT!
Step 1: Chemicals Needed
You will need as follows:
1.potassium nitrate (Its chemical formula is KNO3)
2. sucrose (table sugar)
3.corn syrup
supplies are as follows:
-heated pan
-three clean solo cups
-scale
-stirring spoon
-mortar and pestle
Step 2: Mixing
First you make sure to have a ratio of 70%-30% KNO3 to sucrose
Grind down the sugar and KNO3 to a very fine powder
Next weigh out 7 grams of corn syrup
Heat pan to 300 degrees
add KNO3, sucrose, and corn syrup at once and start stirring
this process will take about 5mins
Step 3: Extract
Use Stirring Spoon to gather together the substance in a clump
Turn heated pan off to let the substance stick together
Scoop up with spoon and put in clear container or a pre-made fuselage
You will have about 90 seconds before substances has fully hardened
