Skate
Introduction: Skate
1、 滑板轮子采用外侧弧形,方便做较高难度的动作,并且加粗轴,增加承重能力。
1. The skateboard wheel adopts the outer arc, which is convenient to do more difficult actions, and the axle is thickened to increase the bearing capacity.
2. 在轮子轴承中间增加球形设计,以方便轮子在不同的角度下都能以最大面着地。
2. Add a spherical design in the middle of the wheel bearing, so that the wheel can land on the ground with the largest surface at different angles.
3、 轴承与板面连接处增加弹簧减震,有助于做高难度动作时轮子的复位。
3. Add spring damping at the joint of bearing and plate surface, which is helpful to the wheel reset in high difficulty action.
4、在轴承与板间增加一个转轴,方便轮子能转更大角度,同时不固定死轴承也有利于减震。
4. Add a rotating shaft between the bearing and the plate, so that the wheel can rotate at a larger angle, and the unfixed dead bearing is also conducive to shock absorption.
5、板面采用一次成型,增加板面韧性,延长使用寿命。
5. The board surface adopts one-time forming to increase the toughness of the board surface and extend the service life.
6、滑板尺寸为高130mm,长800mm,宽200mm。
6. The sliding plate is 130mm high, 800mm long and 200mm wide
Teacher Notes
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Fix It Contest
      Fix It Contest
