Skateboard
This skateboard is white, it represents peace, the green letters represent a good environment, the flanks light blue represent the sky, the wheel plate dark blue represents the sea. Skateboards add flanks to improve the stability of the skateboard. The bottom injector adds power to the skateboard. Make skateboarding a walking tool for people to travel.
Teacher Notes
Step 1: Making Board Slabs
Select a square Adjust to 60 x 20 x 1 in the shape generator
Step 2: Topping
Select an announcement
At the top of the shape generator, adjust the diameter to a width equal to Figure One, thick 1, and then rotate 90 Degree.
Rotation Figure 3 15 degrees up
Step 3: Merge On-board
Copy Align the three figures with the edges of Figure One and group them together.
Step 4: Making Wheels
Select the wheel Shape Generator and expand it
Step 5: Connecting Wheels
Copy wheels Then select a cylinder in the Shape Builder to connect the two wheels.
Step 6: Processing Axles
Select one
Supercapsules in the Shape Generator and group supercapsules with Figure 6, set Transfer to Hollow
Step 7: Connection Board
选择一个框,然后
设置四个凹陷.
Step 8: Connecting Shafts
选择一个气缸
如图所示,以及具有九点组成的变形多边形
Step 9: Making Screws
选择一个扭曲
多边形和圆柱系统插入所示的螺钉
Step 10: Making Nuts
选择一个多边形
和一个扭曲的多边形来制作螺母,如图所示
Step 11: Installation
安全图十
用图XIii的螺丝固定在滑板的底部
Step 12: Installing Wheels
然后安装
图TWELVE中带螺母的车轮。
Step 13: Complete Wheel Installation
依此类推
安装了另一个轮子并显示了滑板。
Step 14: Beautify
定制
文字,然后将冠军添加到滑板。
Step 15: Flank
选择
形状选择器中的元素圆角并调整尺寸。复制元圆角,添加在滑板两端。
Step 16: Injector
选择四支管
在形状选择器中,如图所示对齐,以制作一个注射器。安装
滑板尾部的喷油器。终于完成
滑板的生产。
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
