Skateboard
Skateboard length 80cm wide 20cm high 19.9cm with letters
on top
This skateboard can be exercised on less
smooth ground, increasing the chances of success. The purpose of building skateboards is to reduce the fault tolerance of novices but this skateboard is not mature, so I hope to be guided by the judges
Teacher Notes
Step 1: Wheels
Wheels consist of 4 tubes and a
cylindrical length of 20cm Wheel diameter 4.7cm The remaining tubes are to fix the wheels
Step 2:
The fixed shaft consists of a tube
column, a long square, connected to a support column.
Step 3:
€7cmx3.68cm2x33cm
Step 4:
9.19cmx9cm0 .65cm
Step 5:
0.92cm h 20cm
Step 6:
Step 7:
€2.7cmx5.3cmx5.06cm
Step 8:
€2.44cmx5.52cmx7cm
Step 9:
8.9cmx1cm
Step 10:
Add a spring to the platform can absorb
shock slower or jump higher Spring length 3.2cm
Step 11:
Finally make up a skateboard, skateboard
there's a daughter-in-law.
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
