Skateboard Model
This project mainly introduces the construction process of the author's skateboard
Teacher Notes
Step 1:
First, drag out a box, set the length to 90, the width to 30, and the height to 1.
Step 2:
Drag out a half cylinder, set the diameter to 30, the length to 24.38, and the thickness to 1.
Step 3:
.Adjust the tilt angle of the half cylinder to 13 ° and copy.
Step 4:
.Move the copied other half cylinder to the other side of the box and rotate it 180 ° to align and group the three. Set to black after grouping.
Step 5:
Drag out a box, set its color to gray, and set its length to 26, width to 20, and height to 1.
Step 6:
Drag out another box, and set its height to 1, length to 20, and width to 15.
Step 7:
Align the two boxes on the X and Y axes. As shown in the figure. Form wheelbase.
Step 8:
Drag out 2 cylinders and set the diameter of one of them to 5 and the height to 2.5. The other has a diameter of 2 and a height of 5
Step 9:
Drag the two cylinders onto the wheel base and align them in the x-axis direction, as shown in the figure.
Step 10:
Drag out a half cylinder and set its width and diameter to 6.88, height to 1 and length to 15.22.
Step 11:
Drag out a cylinder with a diameter of 3 and a length of 10.75.
Step 12:
Connect the cylinder and the half cylinder and align them in the x-axis direction. And group them as shown in the figure.
Step 13:
Pull out a spring and set it directly to 3, with a height of 4.
Step 14:
Drag out a box, set its length to 3, width to 2.67, and height to 1. And copy it.
Step 15:
Connect the two small cuboids to the two sides of phlegm yellow and group them.
Step 16:
Drag out 2 triangles, and set one of them to 15 in length and 1 in height, and the other to 20 in height. Copy them once respectively.
Step 17:
Connect to the wheel base as shown in the figure. And divide them into groups.
Step 18:
Move the spring structure onto the small thick cylinder and tilt it 3 °.
Step 19:
The combination of the cylinder and the half cylinder is moved to the place as shown in the figure, and the inclination is 14 ° to connect with the spring structure.
Step 20:
Drag out two polyhedrons respectively. Set the diameter of one to 1 and set to hole. The other has a diameter of 3.
Step 21:
Align the two. And divide them into groups. So a nut is made.
Step 22:
Set the nut to black and move it as shown. Group as a whole.
Step 23:
Drag out a sphere, set the length to 6, the height to 6, and the width to 4. Drag out another cylinder with a diameter of 6 and a length of 2.
Step 24:
Splice and duplicate the sphere. As shown in the figure. Group and set to black.
Step 25:
Drag out a ring and set the wall thickness to 1 and the radius to 6.
Step 26:
Make the ring coincide with the center of the tire.
Step 27:
Connect the tires to both sides of the axle and group them.
Step 28:
Copy. And connect the main body respectively.
Step 29:
Drag out a small cylinder with a diameter of 1 and a height of 2.5. Copy 7 times. Install as shown.
Step 30:
Finally, add a little decoration to the skateboard to make it more beautiful and beautiful.
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
