Skateboarding Introduction
Introduction: Skateboarding Introduction
I am a novice
Teacher Notes
Step 1: At First, Put a Cuboid on the Work Plane,reduce Its Height and Make a Appropriate Length and Width.
Step 2: I Put Another CoboidThen,I Put Another Coboid,which Has the Same Height and Length As the First One.Just Press Alt(or Opt in Mac’s Keyboard)to Copy the Same One.
Step 3: After That,put a Coboid That Has the Same Size As the Central One,just Ruduce Its Length .Then Copy It to Have a Same One.
Step 4: Put a Cut Cylinder
Put a cut cylinder,set its arc to 90,and set a same height as the board.Set cylinder’s radius same as the width of shorter cubiod.Put four cuboids that have the proper length and height to fit the cylinder,meanwhile,put the four around the board.As shown in figure
Step 5: Place Text
Place text on the surface of the main board and input ZZULI,set a hollow form of the text.
Step 6: Make Wheels
Make a slender cylinder as the connected part of the wheels,and put a coboid at both sides of the cylinder to make up one part.Then copy a same part.
Step 7: Finally
Finally,conbine all parts together,you can get a skate!
Step 8:
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Fix It Contest
      Fix It Contest
