Skatepark Coffee Table
Materials needed:
4x 2 feet x 4 feet x 3/4 in board
3x 1 1/2 in x 2 in x 8 ft
Screws
Spray paint
Balsa wood
8 hinges
Step 1: Base
Cut plank to 2 3ft sections. Then cut 2 1ft 9 in pieces. Place them in a rectangular shape. With the smaller pieces being inside the two longer pieces. The rectangles should be 3ft x 2 ft once finished.
Step 2: Base Pt. 2
Cut one of the boards down to 3 ft and screw into the base you made in the previous step.
Step 3: Legs
Cut planks into 4 2ft long boards. Screw then on the inner lip on the base
Step 4: Legs Pt. 2
Cut boards 16 inches long to cover the legs. This is not a necessary part. But it does make the table sturdy and look better.
Step 5: Cover
Cut a piece of the board to 6in x 1ft 10.5 in this will be a side on the shorter side of the table. Use wood glue and center the piece standing upright. Repeat for the other side.
Step 6: Cover Pt. 2
Cut 2 pieces of board to 3ft x 6 in. This will be the siding for the longer sides. Use the hinges to connect it to the table standing upright.
Step 7: Cover Pt. 3
Cut one board into 2 3ft x 1ft boards. This will be the top of the table. It will attach to the sides with hinges so that the table can open into a skatepark.
Step 8: Ramps
Making the inside is the harder part. We made a quarter and half pipe. We cut the access wood into arched pieces and glued them down. This helped the balsa wood we used keep its shape.
Step 9: Stairs
For the stairs we used the extra wood and stacked it with a stagger so it has a simple stair shape.
Step 10: Finish
After everything is glued/screwed down and finished how you’d like, painting it and personalizing it is the fun part.
    • Pie Contest
      Pie Contest
    • Epilog X Contest
      Epilog X Contest
    • Paper Contest
      Paper Contest
    seamster
    10 days ago
    Ha! love it, very clever project. Well done!
