Skater Boy
I like the wind as free, light your gentle, unable to retain, rejoice as supple
Teacher Notes
Step 1:
A cuboid and a half cylinder are spliced an-d combined, and then pasted and copied t-o get a skateboard plane.
Step 2:
Skateboard wheel making pro-ess diagram, cylinder and semi-cylinder splice, and then use an arch to empty the bottom
of the wheel.
Step 3:
Make a small screw out of a hexagonal prism and a cylinder
Step 4:
Combine wheels and screws into one shaft
Step 5:
Splice the base and shaft together
Step 6:
The complete skateboard can be obtained by splicing the fabricated bearing shaft with the surface of the skateboard.
Step 7:
Skateboard multi-angle display
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
