Sliding Plate
Introduction: Sliding Plate
It's a skateboard. It's got two colors and a special pattern. It looks good.
Teacher Notes
Step 1: Manufacturing Edges
long13CM wide21CM
high1CM
*first place the paraboloid on the working plane and make it repeat.
*second expand the scale of repetition and lift it up, then change it into hole and original figure combination. (easy to make curved tips)
Step 2: Manufacture Intermediate
long55CM
wide21CM high1CM
*first place the cylinder on the working plane and repeat.
*second raise the repeating part and change it into the hole and the original figure.(a cylinder is easy to combine with a paraboloid)
Step 3: Combine and Trim
*first combine the
corner and the middle part so that they are 81CM in length
*second trim with two rounded corners(to make the combination of two smoother)
Step 4: Beautify
*first, cut the slide in half with the cube
*second, copy and put them together
*finally, turn color(make the board more beautiful)
Step 5: Manufacture Wheel
diameter5.5CM wide3CM
*First, cut the cylinder with two hemispheres
*second, combine it two rings and a cylinder
Step 6: Manufacturing Support
long7.5CM
wide5.5CM
*first, cut a cube with a cylindrical hole and combine it with a small cylinder(make the bracket more stable)
*second, one hemisphere is cut with a small hemisphere and transformed into a hole and bracket combination(make the shaft smoother)
*third, combine the assembly with two round edges and corners, a small cylinder and an arch(make bracket connection more natural)
*finally, cut two holes for decoration(beautiful)
Step 7: Beauty
Combine all part and add the pattern
Step 8: Finally
Accomplish!
Skateboard Contest
Skateboard Contest
1 Person Made This Project!
  • Magnets Challenge
    Magnets Challenge
  • Snow Challenge
    Snow Challenge
  • Fix It Contest
    Fix It Contest
3 Discussions
Penolopy Bulnick
Penolopy Bulnick
3 months ago
Nice job! I like the design you added, did you use the scirbble option?
1144175828
1144175828
Reply 2 months ago
Ëexcuse me ,why can't participate in the competition.
Penolopy Bulnick
Penolopy Bulnick
Reply 2 months ago
Hi, Typically you have to submit your project to the competition before the deadline which was Monday. But since so many people had issues entering, I can manually add it for you.
