Small Pet Cheap Air Conditioning Unit
177
Introduction: Small Pet Cheap Air Conditioning Unit
About: #upcycle #zerowaste #plasticfreeocean
With the heat wave setting in I'm constantly worried about my rabbit overheating in his hutch. Previously I have been putting baking trays of ice in with him with works but he likes to tip them over and I wondered if there was a better way of doing it at minimal cost. So I came up with the tin aircon unit.
Supplies:
1 tin (deep to fit the ice but make sure it will fit in your freezer draw!) Can be square or round.
1 hand fan
Drill
Bottle/can/wire for holding your fan
Super glue
+/- masking tape
Step 1: Drill Holes
You can be as neat or as messy as you want here. I marked mine out on masking tape. Make sure you drill outside in so the spikes are on the inside. (Be careful, wear gloves, I cut myself!)
I found the drilling bent the tin a bit but it was easy to bend back. The lid i put on a piece of wood so i had something to drill down onto. You want decent sized holes to get air flow through.
Step 2: Attach Fan Holder.
You want to attach something to hold the fan to the lid. If your tin is deep enough you could always put something into the tin to stand the fan bit mine wasnt tall enough. You could attach it with a strip of metal, plastic, some wire, a jar, really any way that works for you just check it works with your tin and fan. I found the bottom of a bottle of fanta worked great. I just super glued it on.
Step 3: Finished
And then that's it. On cooked days I just freeze it and then it's a cold ice box with a bit of ventilation for him to cuddle up against. If it's really hot I can switch on the fan and get a gentle airflow through the hutch for as long as the battery lasts.
Let me know if anyone has done similar!
Pets Challenge
Pets Challenge
Be the First to Share
    • Mason Jar Speed Challenge
    • Pumpkin Challenge
      Pumpkin Challenge
    • Bikes Challenge
      Bikes Challenge
    4 Discussions
    Gale joiner
    Gale joiner
    Question 1 year ago on Step 3
    Will you describe the hand fan? Am interested in this project.
    RuthNmore
    RuthNmore
    Answer 1 year ago
    Yes, it is the kind you tend to pick up at the counter in supermarkets. Costs about £2. Takes 2 AA batteries and stands about 13cm high. I think there designed for people to take around in there handbag or have on your desk at work.
    Gale joiner
    Gale joiner
    Reply 1 year ago
    Thank you for answer. I want to try this. From Boycc, Louisiana, USA.
    Kozmicblues69
    Kozmicblues69
    1 year ago
    This is a great idea! I was worried about the same problem with my Hamster. She moved her nest on the second floor of the cage and now she makes "bivouac". I tried to give her fresh things to eat but I wanted to do something more. So thanks for sharing this idea!
