Small Wooden Bench
Introduction: Small Wooden Bench
i made a small wooden bench out of 7-2x4s.
Supplies:
7- 2x4s
1 1/4 wooden screws
Miter Saw
Table Saw
Drill
Sander
Teacher Notes
Step 1: Table Base
I started by building the table base and by putting my wood together i used wood glue and let it dry up and get glued on.
Step 2: Table Legs
For the legs i use a 2x4 and cut it in half and out of one long 2x4 i cut out all four of the legs and cut them at the size i needed. And i stuck a piece 2x4 in between to make them sturdy.
Step 3: Table Supports
In this step i am putting up all the table support beams and screwing on the table legs. And by doing that i am using a 2x4 for both side going long ways, and then using 2 pieces of wood for the middle so it can stand strong.
Step 4: Putting It All Together!!
In the final step i am grabbing the table top of my bench and finally screwing it together to finish the bench. Where i screw the table top was on the support beams but the screws i use were small so they wouldn't damage anything.
Be the First to Share
    • Trash to Treasure Contest
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
