Smart Bulb Wifi Control, Voice Control, Amazon, Google, Xiaomi
328
5
About: Specializing in the OpenSource Hardware. skype: yichone
This smart bulb is developed by WiFi, which can be controlled by internet, voice (now support Amazon, Google, Tmall, and Xiao Mi).
The full details: [CLICK](https://github.com/SmartArduino/SZDOITWiKi/wiki/Sm...)
alishop: [CLICK](https://www.aliexpress.com/item/DoHome-Smart-Wifi-...)
amazon shop: [CLICK](https://www.amazon.co.uk/dp/B07DPMF6PL)
Step 1: Parameters
  • Model: DoLED05
  • Mode: Wi-Fi
  • APP Name: DoHome
  • OS version: Android 4.0/IOS9.0
  • Channel: 4(RGBW) Watt: <7.5W
  • Power Factor: 0.6
  • Lumen: 550lm Luminous Angle: 120
  • Temperature: 3000K, RGB
  • Beads Number: RGB: 5050-0.2W*5, warm white: 2835-0.5W*16
  • Working Voltage: 100-264VAC, 50/60HZ
  • Lampholder: E27 B22
  • Effective control of distance: 40 meters for visual distance
  • Material: shade: PC, holder: aluminum
  • working time: 40000H
Step 2: Specifications
  • Brightness adjustment
  • 16 million color
  • Heating adjustment
  • Custom pattern
  • Timing delay
  • Mobile phone control
  • Remote upgrade
  • Voice control
  • Tmall Genie
  • Google assistant
  • Amazon Alexa
  • Xiao Mi
Step 3: Q & A
Q: What is the WiFi name for this bulb? and its password?
A: The SSID is “DoHome_xxxx”, where, xxxx is denoted the ID for this device, and the default password is 12345678.
Q: When add the device, if pop a message says whether accept APP to get the location, how to handle it? A:This is very important. Must click "accept or Yes".
Q: At step 3.2, if the progress bar is 0% and then don't move, how to do it? A: there is two ways: Open the phone WiFi setting, select "forget/don't save" the WiFi signal "DoHome_xxxx" for this device, and then go on the WiFi configuration by the above; Manually connect the WiFi signal "DoHome_xxxx", and press the phone return key to back "DoHome" interface.
Q: If I want to use the voice function, What are the issues to be aware of? A:1) please make sure that the device have already open the remote function, and bind the DoHome account; 2) Any problem, please click the menu logo to get the help for the other applications.
Q: How to restore the system? A: on/off device for 5 times with each 2s to restore the factory setting. Note, if the time is too long for each time, then would re-compute the number of times.
Q: Why should the device name be short? A: Convenient for the voice control, for example, DoHome.
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
