Smartphone / Tab Controlled ROBOT ARM !!
7,815
60
7
Introduction: Smartphone / Tab Controlled ROBOT ARM !!
About: A Computer Science and Engineering student and a Hobbyist. love to make robots,electric devices,diy things and Programming them by Myself. My youtube channel https://www.youtube.com/fussebatti Follow me on ...
Making ROBOT ARMs is very popular and fun among hobbyists,but it's not that easy to control a ROBOT ARM. So today we'll be making a robot arm that can be controlled using just your Android Smartphone or tablet.
Good news is, you just need to program the Arduino, the App is already available to download for free.
Watch the video for full tutorial
Step 1: Parts You'll Need
1. Servo motor 4x (I'm using micro servo Sg90 but any model or size is okay)
you can use upto 5 servo for this robot arm,I've only 4,so I'm using them.
2. sliced piece of Card Board - to make the body.
3. USB OTG (on the go) [pic3 & 4- all the same]
4. And of course a Arduino board (any board)
6. And a few jumpers to make the connection
7. And a 9v battery to power the servo motors.
Buy electronic parts ar utsource.net
Step 2: Making the Robot Arm (THE BODY)
Now in here I'm actually making the body in a way so that I can easily connect and disconnect the ARM anytime. Using some pieces of cardboard and Hot glue I've mounted the Servo motors to the cardboard to make the body. It's better to watch the video to better understand how it's done.
Step 3: Making the GRIPPER (finger for Robot Arm)
I've made the robot gripper using juice straw or pipe. And added a simple fiver or rope so that when it's pulled the grip will be closed .
Step 4: Assemble the Robot ARM
after making the arm and making & the gripper you just assemble the body as shown.
Step 5: The Circuit
Well the circuit is very easy,you just need to power the servo motors. Arduino will take power from your phone via OTG cable. Don't worry, the power consumption is very low.
Step 6: Download the ANDROID APP
Search on google PLAYSTORE - Servo & Esc controller.
Download from here https://play.google.com/store/apps/details?id=com....
Then Install the app.
Step 7: Programming the Arduino
You can get the code from the link in the app, I'm providing the code below
# include <Servo.h>
//PWM OUTPUT VARIABLES
Servo pin2;
Servo pin3;
Servo pin4;
Servo pin5;
Servo pin6;
//SERIAL USB BUFFER
char inData[ 65 ]; // Allocate some space for the string
char inChar; // Where to store the character read
byte index = 0 ; // Index into array; where to store the character
void setup () {
//START PIN OUTPUT
pin2. attach ( 2); // attaches the servo on pin 9 to the servo object
pin3. attach ( 3);
pin4. attach ( 4);
pin5. attach ( 5);
pin6. attach ( 6);
//SEND MINIMAL VAUE 1000, REGUIRED FOR ESC TO ARM (max is 2000)
pin2. writeMicroseconds (1000 );
pin3. writeMicroseconds (1000 );
pin4. writeMicroseconds (1000 );
pin5. writeMicroseconds (1000 );
pin6. writeMicroseconds (1000 );
//INIT SERIAL COMMUNICATION WITH ANDROID
Serial. begin (115200 );
void loop () {
if (Serial. available () > 0 ){
//WAIT FOR INCOMMING DATA BUFFER TO FILL
if (index < 24){
inChar = Serial. read (); // Read a character
inData[ index ] = inChar; // Store it
index ++; // Increment where to write next
if (inChar == 'X' )
index = 0 ;
inData[ index ] = '\0' ; // Null terminate the string
if (index ==24 ){
index = 0;
//STRING LOOKS LIKE "A100B96C20D0E" WHERE LETTERS ACT AS DELIMINATOR
//STRING CAN CONTAIN SINGLE VALUE LIKE "B96C"
String buf = String (inData);
int ia = buf. indexOf ( "A", 0);
int ib = buf. indexOf ( "B", 0);
int ic = buf. indexOf ( "C", 0);
int id = buf. indexOf ( "D", 0);
int ie = buf. indexOf ( "E", 0);
int iff = buf. indexOf ("F" , 0 );
Serial. print ("|" );
//A?B
if (ia!=- 1 && ib!=- 1){
//1. CONVERT VALUE TO INTEGER
//2. CONVERT 0-100 TO 1000 - 2000
//3. WRITE TO ARDUINO PIN NUMBER 2
pin2. writeMicroseconds (map (buf. substring (ia+ 1, ib). toInt (), 1, 100 , 1000 , 2000 ));
//SEND RESPONSE TO ANDROID
Serial. print ( "RESPONSE:OK" );
//B?C
if (ib!=- 1 && ic!=- 1){
pin3. writeMicroseconds (map (buf. substring (ib+ 1, ic). toInt (), 1, 100 , 1000 , 2000 ));
//Serial.print("PIN3 OK");
//C?D
if (ic!=- 1 && id!=- 1){
pin4. writeMicroseconds (map (buf. substring (ic+ 1, id). toInt (), 1, 100 , 1000 , 2000 ));
//Serial.print("PIN4 OK");
//D?E
if (id!=- 1 && ie!=- 1){
pin5. writeMicroseconds (map (buf. substring (id+ 1, ie). toInt (), 1, 100 , 1000 , 2000 ));
//Serial.print("PIN5 OK");
//E?F
if (ie!=- 1 && iff!=- 1){
pin5. writeMicroseconds (map (buf. substring (ie+ 1, iff). toInt (), 1 , 100 , 1000 , 2000 ));
//Serial.print("PIN6 OK");
Serial. print ("|00" );
Serial. print ("\n" );
void logg (){
Step 8: Connect the OTG and Arduino to Phone
Connect the OTG cable to arduino programming (USB B) cable and then connect the wire with the phone. The APP will automatically pop up . Click on 'ok' and twill open. After connecting "port open" message will be seen.
Step 9: Finished
And you're done,just power the Servo and use the app to rotate every single servo of the arm as you please. So Simple.
Thank you.
Please support by subscribing my youTube channel
Make it Move Contest
Be the First to Share
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    • Backyard Contest
      Backyard Contest
    7 Discussions
    Md.I4
    Md.I4
    9 months ago on Step 7
    vaia code ta cope kore ei id te pathai den plz
    Ashraf Minhaj
    Ashraf Minhaj
    Reply 4 months ago
    App er option e achhe
    Md.I4
    Md.I4
    Reply 9 months ago
    vaia apner number ta den plz
    Tushar456
    Tushar456
    Question 4 months ago on Step 7
    Where is the code link
    Ashraf Minhaj
    Ashraf Minhaj
    Reply 4 months ago
    It's in the app settings or option menu
    Ashraf Minhaj
    Ashraf Minhaj
    Reply 4 months ago
    The code is provided in the apk.
    jm11001034
    jm11001034
    1 year ago
    This Does not Work on Iphone!!!
    Don't make the mistake i did if you have a iphone
