Snake Plant
480
7
12
Introduction: Snake Plant
To make this Snake Plant you will need the following material:-
PVC sheet white color (0.5 mm) for leaves, 3 mm white Acrylic sheet for pot, Acrylic colors, Super glue, Heat gun, copper wire or any soft wire, gum stick and White Marble chips.
Step 1: How to Make Leaves
Take print out of the leaves (file attached). Paste the print out on the PVC sheet with glue stick. Cut out the leaves, soak the leaves in water to remove the paper. Let it dry, paint these leaves with acrylic paints and let it dry. Now take a leaf place it on sponge. Heat it with a heat gun. check if the leaf is soft then give it the desired shape. Make a hole at the bottom of the leaf so wire can pass through and fix the wire.
Step 2: How to Make a Pot
Take a print out (file attached) and paste it on a 3mm acrylic sheet. Now cut with the help of tools. Join the cutting pieces with super glue.
Step 3: Final Assembly
Pass the leaves wire from the tiny holes of the mesh. Arrange all the leaves and twist the wires and join them together by twisting them in one another. Arrange all the leaves in such a way so they give a natural look. Cover the pot surface with white marble chips. Enjoy the art piece!
Colors of the Rainbow Contest
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Puzzles Speed Challenge
    12 Discussions
    daisyflag82
    daisyflag82
    1 year ago
    Very Nice work ... i like it very much
    kz creative
    kz creative
    Reply 3 months ago
    Thank you
    ThomasAndTugs
    ThomasAndTugs
    1 year ago
    Great job! One tip though- change the name to "fake snake plant" as I thought it was a picture of a snake plant and misjudged it as being some instructions on how to care for a plant (which wouldn't fit in the contest.)
    kz creative
    kz creative
    Reply 1 year ago
    Thanks for your tip, you are right
    audreyobscura
    audreyobscura
    1 year ago
    This is a good fake!
    kz creative
    kz creative
    Reply 1 year ago
    Thank you
    rocket radhi
    rocket radhi
    1 year ago
    Nice one, i thought it was real
    kz creative
    kz creative
    Reply 1 year ago
    Thank you
    AnandM54
    AnandM54
    1 year ago
    Impressive one !!
    kz creative
    kz creative
    Reply 1 year ago
    Thanks
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    That looks great and I love how you connected them underneath since it looks like roots intertwining :)
    kz creative
    kz creative
    Reply 1 year ago
    Thanks for your appreciation!
