Soil Moisture Detector
Introduction: Soil Moisture Detector
班級姓名:
9D 林心蓉 Flora Lin
簡介: For my Arduino project, I wanted to make something meaningful that can actually help me solve the problems that I face in my life. I thought about the things I struggled with and the first thing that came in my mind is how I always forget to do things and one of those things is watering my plants. So I made a device that would automatically remind me to water my plants if/ when the soil gets too dry. This way the device would not only be a project for school but also can be really useful in my life too
來源: http://www.circuitstoday.com/arduino-soil-moistur...
I didn’t completely follow the tutorial, as you can see, the circuit and codes are different, I only used this website to get ideas and see the materials I needed. I added the alarm that would actually remind me to water the plant.
Supplies:
6.材料清單:
Materials needed for this project are:
1k resistors x1 Image result for resistor
LED light x1 Image result for led light arduino
10k piezo Buzzer x1Image result for piezo buzzer
Soil moisture detector set x1 Image result for Soil moisture detector set
Assorted wires Image result for arduino wires
Arduino Leonardo x1 Image result for arduino leonardo
Breadboardx1Image result for breadboard
Step 1: Procedure for Making the Device Pt.1
CIRCUIT
Step 1 In case the picture wasn’t clear enough,
GND >> -
5v >> +
for the moisture sensor:
AO >> GND
DO >> A0
VCC+ >> +
For the buzzer:
+ >> pin 6~
For the LED light:
Anode >> Resistor >> pin 7
Cathode >> -
Step 2: Procedure for Making the Device Pt.2
PACKAGING
Step 1: find a box that fits the board
Step 2: Measure a hole on the top of the box to stick the sensor out
Step 3: cut out the hole
Step 4: find and measure a hole big enough to fit the USB cord
Step 5: cut out the hole
Step 6: also on the top of the box, cut a smaller hole to put the LED light through
Step 7: place the device in the box with the USB cords plugged in and seal the box
Step 3: Procedure for Making the Device Pt.3
TESTING
Step 1: find some dried out soil
Step 2: place the sensor in the soil and check that the buzzer and LED lights work properly
Step 3: pour water in the soil and check if it properly detected the moisture and stopped the alarm
Step 4: Conclusion + Final Product
In the end despite all of the frustrating times where I would get stuck on a line of coding or when I had to start over because it did not work, I was pretty proud of the device that I made. It was not only useful, but I also learnt a lot on the way, I pushed myself to do more even when I didn't want to and I improved my computer skills a lot during the duration of this task.
The video of my device actually working is here:
THANK YOU !!!
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
