Solar Monitoring System Board
Introduction: Solar Monitoring System Board
About: I love Arduino, Raspberry Pi and make project.
Solar monitoring system measures voltage, current and power from panel, and from two outputs and voltage on battery.
This board measure input voltage, current and power from two sources. Board have two outputs. Each have voltage, current and power measuring. Voltage, current and power measure with INA219 board from Adafruit. Input from solar panel is completely isolated from ESP8266 and 5V. Every inputs and outputs have 3A fuse. I measure temperature and humudity inside box with AM2301 and measure heating temperature with termocoupler and MAX6675. I2C bus is connected via level shift converter to ESP board.
Thank you for reading, like and write comments.
This project is sponsored by LCSC component.
Step 1: Step 1: Hardware Components
Adafruit INA219 3pcs
NodeMCU ESP8266 Board 1pcs
Watch Dog Timer 1pcs
Max6675 with termocoupler 1pcs
AM2301 Temperature and Humidity sensor 1pcs
AM1D-0505SZ Isolated DC/DC converter 1pcs
ADUM1250ARZ - I2C digital isolator 1pcs
Terminal Block 2p 11pcs
1A Fuse with socket 1pcs
3A Fuse with socket 4pcs
Step-down converter 12V/5V 1pcs
Logic level converter (Bi-directional) 1pcs
Schottky diode 2pcs
Jumper wires
Computer with Arduino IDE
Raspberry Pi with MQTT borker and Node-Red
Soldering iron with solder
Step 2: Step 2: Wiring and Schematics
SDA - GPIO5
SCL - GPIO4
AM2301(DHT) - GPIO2
WatchDog IN -GPIO15
WatchDog OUT - RST
MAX 6675 SCK - GPIO14
MAX 6675 CS - GPIO12
MAX 6675 SO - GPIO13
Step 3: Step 3: Description of PCB
On the top is a solar charge controller connected to the measuring board.
From bottom left - Two inputs terminal, battery terminal, two outputs terminal, NodeMCU with level shift cenverter, MAX6675 board. On top right is WatchDOG timer.
Step 4: Step 4: Code
Step 5: Step 5: Node Red
Foto from Node Red Dashboard.
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    • Audio Challenge 2020
