Emergency Solder Iron (for Candle)
Its highly conceilable fast and usefull. Made easy. Ready in 15 sec.
Supplies:
Solder iron made easy from 3 parts:
1. Copper 5 cm long
2. Antena from old radio
3. Handle from steel wire.
For operations you will need:
1 candle
2 aspirin pill
3 lighter
Teacher Notes
Step 1: Solder Iron Assembled
All three parts when assembled.
Put copper wire inside antena pipe with same diameter. I grinded it a little to be able to fit inside. At the other end put steel wire with same diameter.
Step 2: How to Use
Use it with candle.
Put the flame only to copper.
Clean copper part for best effect.
I use it for years, becouse of easy conceilability and travel sizes.
It works great, heats fast - in about 15 sec.
Its usable with other sources of flame like alcohol.
I have made upgrade to electric for stationary use - just one old fuse(ceramic) and heater wire (cantal) from old water heater. Only 24 volts, becouse of open wires.
Be the First to Share
    • Made with Math Contest
    • Cardboard Speed Challenge
    • Multi-Discipline Contest
    joen
    4 weeks ago
    Years ago I had to make a solder repair and my soldering iron didn't work. I held a nail with a needle nosed pliers over a candle as an emergency soldering iron. I still can't get over how well it worked! From my own experience I can say this does work. Thanks for posting this for others who may need this info.
