Sonoff Wall Switch
Supplies:
small piect of 1/4" plywood
Yosoo Spring Pressure Test Probe Pogo Pin P50-B1 Dia 0.68mm Length 16mm 75g Pack of 100 Gold $8
5V 3.3V FT232RL FTDI USB to TTL Serial Adapter Module for Arduino Mini Port
simple on/off switch
Teacher Notes
Step 1: Starting the Project
OK, just another Sonoff project. There's another one where you replace a wall switch but the code wasn't shown and didn't work the way I wanted it to work - so, here's mine.
First I've created a small jig to program my Sonoff's. I've used spring probes rather than soldering in pins. ie: vacuum board. That way I simply set the board in place, press the button, flip switch from off to on, hold for a couple of seconds and then upload.
Once programmed I can web to http://[IP]/on or off or "curl http://192.../on"
Step 2:
I can't get the code to display less than and greater than to display - so it's "LT" and "GT"
#include LTESP8266WiFi.hGT
#include LTWiFiClient.hGT
#include LTESP8266WebServer.hGT
IPAddress ip( 192, 168, 0, 132 );
IPAddress gateway( 192, 168, 0, 1 );
IPAddress subnet( 255, 255, 255, 0 );
// Replace with your network credentials
const char* ssid = "Wood******";
const char* password = "43f********";
ESP8266WebServer server(80);
int relayState = 0;
int relay = 12;
int led = 13;
int button = 0;
int button_state = 0;
LTa href=onGTLTbutton style=background-color:green;color:white;width:100px; height:40px;GTLTbGTLTbigGTGTONLTLT/buttonGTLT/aGT LTa href=offGTLTbutton style=b ackground-color:red; color:white;width:100px; height:40px;GTLTbGTLTbigGTOFFLT/buttonGTL T/aGT";String webPageOn ="
String webPageOff =LTa href=onGTLTbutton style=background-color:green;color:white;width:100px; height:40px;GTLTbGTLTbigGTONLT/buttonGTLT/aGT LTa href=offGTLTbutton style=back ground-color:red; color:white;width:100px; height:40px;GTLTbGTLTbigGTGTOFFLTLT/buttonGT LT/aGT";
void setup(void){
// preparing GPIOs
pinMode(led, OUTPUT); digitalWrite(led, HIGH);
pinMode(relay, OUTPUT); digitalWrite(relay, HIGH);
pinMode(button, INPUT);
Serial.begin(9600);
delay(3000);
WiFi.config (ip, gateway, subnet);
WiFi.begin ( ssid, password );
// Wait for connection
while (WiFi.status() != WL_CONNECTED) {
delay(500);
server.on("/", [](){
if (relayState == 0)
server.send(200, "text/html", webPageOff);
else
server.send(200, "text/html", webPageOn);
server.on("/on", [](){
digitalWrite(relay, HIGH); // Relay On, Led Off
relayState = 1;
delay(300);
server.on("/off", [](){
digitalWrite(relay, LOW); // Relay Off, Led On
digitalWrite(led, LOW);
relayState = 0;
delay(300);
server.begin();
void loop(void)
button_state = digitalRead(button);
Serial.print (button_state);
// Has the button been pressed - if so toggle
if ( button_state == 0 )
digitalWrite(led, HIGH); // Led Off
relayState = 1; // save state
} else {
digitalWrite(led, LOW); // Led On
relayState = 0; // save state
delay (300); // worry about bounce
server.handleClient(); // anything via the wifi
delay (300);
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
