Sonos Like Spotify Wifi Speaker
6,511
93
24
Introduction: Sonos Like Spotify Wifi Speaker
About: Hello, My name is Rien, I am 17 years old and I am from Belgium (next to France, Holland and Germany). I love creating electronic projects, so follow me to see all my project. I am right now in my last year ...
In this project we will build a Wifi Speaker that has Spotify Client build in. This means that you can easily choose in spotify to play on that specific speaker. You don't have to deal with crappy bluetooth since this is based on the ethernet. Your music will even play further if you accidently close your Spotify. It is like a Sonos but then made on your own.
It is based on the Raspotify software for Raspberry Pi. This is an easy to use and not so hard to setup software.
I tried my best to explain everything as simple as possible so that everyone can build this, even the beginners that never builded something before should be able to recreate this.
Teacher Notes
Step 1: Parts Used
Before you start this project, I advise you to buy all the parts.
  • Raspberry Pi 4
  • micro SD card (at least 8GB) (+if necessary an adapter)
  • Computer
  • Speakers and amplifier (look at step 4)
  • Tools
  • Power supply (look at step 6)
Now that you have everything, the real fun can start.
Step 2: Installing Raspbian
Before we can start the project, we have to install an operating system on our Raspberrry pi. In this case we will use "Raspbian Buster with desktop and recommended software".
Installing Raspbian on the Raspberry Pi is pretty straightforward. We’ll be downloading Raspbian and writing the disc image to a microSD card, then booting the Raspberry Pi to that microSD card.
You’ll need a microSD card (go with at least 8 GB), a computer with a slot for it, and, of course, a Raspberry Pi and basic peripherals (a mouse, keyboard, screen, and power source).
Step 1: Downloading the OS
Raspian can be installed from this website. We have to install "Raspbian Buster with desktop and recommended software". Now click on "Download ZIP" and the download should start. (this can take a couple of minutes depending on your ethernet connection)
Step 2: Writing the image to the SD card
Now you will need to download & install the software that will write the image to the SD card. A good one to use is called Etcher, and it works on all platforms (Linux, Mac, and Windows). You’re able to download it from over at their website.
1. Once you have downloaded Etcher, follow the prompts to install it.
2. Insert your SD card into your computer. (Because some computers do not have an SD card reader, you may need to use a USB adapter.)
3. Open Etcher and select the Raspbian image that we just downloaded.
4. Select the SD card that you wish to install Raspbian on. Double check to make sure it’s the correct drive as this will wipe it clean.
5. Once you have confirmed the image and the drive you can then proceed to flash the SD card, select Flash.
6. Once it’s finished, you can safely remove the SD card from the computer.
7. Insert the SD card into your Raspberry Pi and any other extra cords such as power, mouse, keyboard, and the HDMI cord.
8. Now you will be guided through the setup proces. Make sure you don't forget to connect to the ethernet because Spotify Connect is based on the Ethernet. The setup proces is pretty straight forward, so it shouldn't be a problem.
9. You've now succesfully installed Raspian on your Raspberry Pi and you can proceed to the next step. Congrats!
Step 3: Installing Raspotify on the Raspberry Pi
Raspotify is a Spotify Connect client for Raspbian on the Raspberry Pi that Just Works™. Raspotify is a Debian package and associated repository which thinly wraps the awesome librespot library by Paul Lietar and others. It works out of the box on all three revisions of the Pi, immediately after installation.
The install itself is as easy as it gets, just follow the following steps and you'll be up and running in 5 minutes.
1. Open the Terminal using the shortcut "CTRL + ALT + T"
2. Type in the Terminal the following and hit enter afterwards. This command downloads and installs the Debian package and adds its apt repository, which ensures you'll always be up to date with upstream changes.
curl -sL https://dtcooper.github.io/raspotify/install.sh | sh
3. After the installation we will run a quick check. Open your Spotify and look for Available Devices. There should be a "raspotify (raspberrypi)" speaker available like shown below.
4. Now that everything works we can configure Raspotify. By typing the following command in the Terminal, we can change the settings, like the name that we want to be displayed on Spotify.
sudo nano /etc/default/raspotify
5. After you've hit enter, you should see the following.
What you've opened is the Raspotify config file. Within this file, you will see multiple different options that you can configure yourself. We will change only 2 settings: the Bitrate and the Device Name.
6. To change the device name, we will have to uncomment the line first. This can be done by hitting the delete key, your text of that line will now become white. Now we can pick a name that will be displayed in Spotify, I chose Dining Room because that is the place where my speakers will be sitting. Just replace raspotify with the name you want.
For example:
DEVICE_NAME="Dining Room"
7. After we've changed our name we will change the Bitrate. This will give us a little bit better audio quality.
Uncomment the line and replace 160 by 320.
BITRATE="320"
8. Now the code should look like this, except for the name difference.
<p># /etc/default/raspotify -- Arguments/configuration for librespot<br>
# Device name on Spotify Connect
DEVICE_NAME="Dining Room"</p><p># Bitrate, one of 96 (low quality), 160 (default quality), or 320 (high quality)
BITRATE="320"</p><p># Additional command line arguments for librespot can be set below.
# See `librespot -h` for more info. Make sure whatever arguments you specify
# aren't already covered by other variables in this file. (See the daemon's
# config at `/lib/systemd/system/raspotify.service` for more technical details.)
# To make your device visible on Spotify Connect across the Internet add your
# username and password which can be set via "Set device password", on your
# account settings, use `--username` and `--password`.
# To choose a different output device (ie a USB audio dongle or HDMI audio out),
# use `--device` with something like `--device hw:0,1`. Your mileage may vary.
#OPTIONS="--username  --password
"</p><p># Uncomment to use a cache for downloaded audio files. Cache is disabled by
# default. It's best to leave this as-is if you want to use it, since
# permissions are properly set on the directory `/var/cache/raspotify'.
#CACHE_ARGS="--cache /var/cache/raspotify"</p><p># By default, the volume normalization is enabled, add alternative volume
# arguments here if you'd like, but these should be fine.
#VOLUME_ARGS="--enable-volume-normalisation --linear-volume --initial-volume=100"</p><p># Backend could be set to pipe here, but it's for very advanced use cases of
# librespot, so you shouldn't need to change this under normal circumstances.
#BACKEND_ARGS="--backend alsa"</p>
10. To save the file hit "CTRL + X" followed by "y" and last but not least hit enter.
11. Restart Raspotify by using the following command.
sudo systemctl restart raspotify
Give it a quick check like we did in step 3 and look wheter the name has changed or not.
12. Now everything is ready and we can make our speakers ready!
Step 4: Deciding Which Speaker to Use
In this project I will go over 2 types of speakers. The ones that are already amplified and the speakers that are not amplified yet.
The pre-amplified speakers are the easiest to deal with because you just have to connect an aux cable to its input. That makes these type of speakers the best choice for people that don't know much about electronics or just like a more out of the box experience.
The speakers that are not amplified already are a bit harder to work with. We will have to connect an amplifier to the speakers and build a case around that. This is a great way to re-use old bookshelf speakers, like I will do. We will add a cheap amplifier from China to reduce our overall costs. If you love doing DIY projects, you can even build a bookshelf speaker yourself. I recommend the one from this Instructable. I used the speakers from my old Phillips Streamium MCI900. Unfortunatily the Amplifier of it broke, so I now it is a non-amplified speakerset. We will also need a power supply to power our project, but we'll talk about that in a minute.
If you use a pre-amplified speakers, you can go the next step.
If you use a non-amplified speakers, you can skip the next skip.
Step 5: Connecting Pre-amped Speakers
If your speakers are already connected to an amplifier that has an AUX port, you should just connect an aux cable from the Raspberry Pi to the amplifier and disconnect the pheripherals from the Raspberry Pi. Everything should work right now! Make sure you don't disconnect the Power Cable and Ethernet Cable(only when your not connected via Wifi) as well as the AUX cable. You should have kind of the same connections as in the image below and now you are finished. You created a sonos like speaker with a Raspberry Pi and you can start listening to music.
Note that the ethernet cable is not necessary.
Step 6: Picking the Right Amplifier
How to choose the right amplifier and power supply? That's the question we will be answering in this step.
1. How many watts do you need? This should be listed in the specifications of the bookshelf speaker. I have two speakers that use 50 watt each. Thats means I have to buy a 50 * 2 amplifier. Just go an sites like ebay, amazon, alibaba and search for "2 * 50W amplifier". The only thing the amplifier should have is an AUX port. You can buy one with bluetooth as well, but it's not necessary. I wen with this one. It's a 2 *50W Amplifier based on a TPA3116 chip. This will suit my speakers.
2. What power supply should I buy? The power needed to power your amplifier is listed at the amplifiers specification sheet. Mine needed 24V so I had to buy a 24V power supply. The amperage needed can be easily calculated with this formula: I = P(watts) / U, so in my case I have to do 100 / 24 = 4.16 ==> So I need a 24V 4.2A power supply. Its better to go for a higher amperage PSU, so you don't put too much stress on the power supply.
I had an old laptop charger laying around, that outputs 24V and 100watts. So I decided to use it. If you don't have such a power supply laying around, you can you use industrial ones like shown in the picture below. They have a very good bank for the buck.
Step 7: Connecting Everything Togheter
The connection is different for every amplifier, but the principal is the same. This was my schematic, your's should look the same.
Power supply:
Connected to AC wall outlet.
Blue wire to N
Brown wire to L
Green/Yellow wire to GND
V+ --> DC + of amplifier
V- --> DC - of amplifier
Raspberry pi:
USB C to wall outlet
AUX cable to amplifier
(Ethernet cable to router)
Amplifier:
DC out - to speakers
DC out + to speakers
Eventually you will end up with something like in the image below. Now Everything should run fine and your new WIFI speakers are ready to play some music.
Step 8: Building the Enclosure
You could if you want to build a really nice enclosure for the electronics, but it is not necessary. I just putted my electronics in a lunchbox, since I will hide the lunch box. I drilled holes for the potentiometers and drilled mounting holes for the amplifier and Raspberry Pi. My powersupply is from a laptop charger, so I decided to not put it in the lunchbox to safe some space. But if you bought the industrial it is necessary to put the PSU inside the box for safety reasons.
I don't think that my lunchbox looks any good, but like I said it will be hidden. But withouth further ado, here are some pictures of my lunchbox amplifier!
Step 9: Finished Product
I am very happy with the end result. The audio quality is pretty good espacially when you consider that the project only costed me 60 euros in total. The look of my amplifier still needs some work though.
I think it is pretty cool that you can have a Spotify Client build into your already existing speakers. It is just so conviennent that you don't have to connect via bluetooth like most speakers. You can just choose what speaker you want in a click of a button. It's just like a Sonos speaker but then for dirt cheap.
Here are some pictures of the end result!
Raspberry Pi Contest 2020
2 People Made This Project!
  • LED Strip Speed Challenge
  • Sculpting Challenge
    Sculpting Challenge
  • Clocks Contest
    Clocks Contest
24 Discussions
andybiker
andybiker
8 weeks ago on Step 9
Hi,
It's nice to see someone else doing this with a Pi.
I have been using a raspberry pi to do this for years. You certainly don't need a pi4! a raspberry pi zero works very well.It hasn't got a 3.5mm jack but that's not a problem.
The audio out of the 3.5mm jack on a pi is - well, awful.
It seems ok until you try alternatives.
A usb sound card works well and is a real improvement. a cheap one is MUCH beter than the standard Pi output.
The best output is to use an I2S DAC. This does not have to be expensive.
https://www.aliexpress.com/item/4000049217053.html...
This one straight from China for less than 3 UK pounds is superb!
No hiss or noise and CD quality!.
Piggy-backs on top of Pi zero to give a tiny player!
In case you think a pi zero isn't fast enough, mine streams internet radio (controlled via MPD), displays time, artist, song, station scrolling on a large (fruit machine) VFD.
If you connect through spotify, it stops the radio and plays your spotify instead.
The Pis are great!
Best of luck!
vanroeyrien
vanroeyrien
Reply 8 weeks ago
Thanks for the tips. I know the Raspberry Pi 4 is overkill, but that's what I had laying around. I will probably replace it with a Pi zero when I need my Pi 4 for a project that needs some extra power. Also I just bought your recommended sound card!
Also I might move over to MPD, it just looks a bit better and you can use Soundcloud.
andybiker
andybiker
Reply 8 weeks ago
You can use both!
I use mpd (controlled by mpdroid on my phone) for streaming radio and files on a nas drive.
There's a feature of raspotify that allows you to run a command on start of play and on stop.
When starting a spotify stream I pause mpd, when i stop spotify i play the radio.
It gives me the best of both worlds.
Pi zero W (10 uk pounds & sound card 2.5 ukp) makes a cheap radio and spotify connect.
I have 2 in different rooms.
I'll try dig out i2s config details.
vanroeyrien
vanroeyrien
Reply 8 weeks ago
Thanks
at-bh
at-bh
Reply 12 days ago
Hi andybiker,
great idea, just small questions,
what type of PI Zero W Your recommend and what soundcard You recommend?
I detail how the soundcard will be conneced to the PI Zero W ?
Do have hints?
Thanks in advance
andybiker
andybiker
Reply 10 days ago
Hi At-bh,
I use a standard raspberry pi zero W.
9.5 ukpounds. simple cheap i2s sound card (link given) about 3 ukpounds.
you can also get them from ebay or amazon.
I have given the pin connections further down this chat.
the sound quality is superb.
configuration clues also given further down.
let me know how you get on.
at-bh
at-bh
Reply 9 days ago
Great ... Your answer is very helpful, I was ordering all the stuff and I will give You the feedback (with pics) afterward.
Thanks a lot so far.
vanroeyrien
vanroeyrien
Reply 9 days ago
Nice to see that you are making this projects. If you have any questions or get, you can always message me!
drewcssv
drewcssv
7 weeks ago
Great project and Instructable that’s super easy to follow. BTW, how did you get those photos inline with your text instead of at the top where they are hard to reference? Your method makes it really easy to follow. Thanks again.
drewcssv
drewcssv
Reply 5 weeks ago
Hi thanks for the link! I looked and found that it might be a bit dated as it's 2012. Seems the Instructables UI has evolved and doesn't have that method available. When I try to manually insert the link using the <html> tags it seems to work but doesn't survive a SAVE. So not sure how to proceed.
vanroeyrien
vanroeyrien
Reply 4 weeks ago
Well, for me it just worked. Maybe search for a newer instructable on that topic?
mrjohnson1100
mrjohnson1100
Question 7 weeks ago
What types of pre-amplified speakers would work with this? In looking online I'm not sure what to use as search words. I'm looking for something where I could get 3 or so speakers for the price of one of the Sonos speakers.
vanroeyrien
vanroeyrien
Answer 7 weeks ago
Well every pre-amplified speaker that has an aux port will work. So you have a lot of choice. If you give me your budget for the speakers and your region, I can give you a recommendation.
mrjohnson1100
mrjohnson1100
Reply 7 weeks ago
I'm in the US and my budget is around $50 per speaker, I'm even willing to make them once I find what I need, that will let me look for instructables for making speakers (something that I've always wanted to try).
vanroeyrien
vanroeyrien
Reply 7 weeks ago
andybiker
andybiker
7 weeks ago
The I2S board has 10 pins.
VCC - to pi pin (2)
3.3 - via 1k resistor to last pin (XMT)
GND to pi pin (6)
FLT join to GND
DMP join to GND
SCL join to GND
BCK to pi pin (12)
DIN to pi pin (40)
LCK to pi pin (35)
FMT join to GND
XMT join to 1k resistor from 3.3
The connection to the xmt pin had me fooled. it's an enable! if left off, it will "sometimes" work!
The dac is a BurrBrown PCM5102 and uses the HifiBerry-dac overlay.
how to configure..... apologies if I leave something out...
first we edit /boot/config.txt
sudo nano /boot/config.txt
You will need to change the following things:
Uncomment (remove the # before the line):
dtparam=i2s=on
Comment (add a # before the line):
#dtparam=audio=on
(this line above disables the onboard sound)
Append this to the end of the file:
dtoverlay=hifiberry-dac
now save this (escape : w q )
now create etc/asound.conf
sudo nano /etc/asound.conf
And write the following:
pcm.!default {
type hw card 0
ctl.!default {
type hw card 0
reboot your Pi!
I hope you enjoy!
Cheers,
Andrew
vanroeyrien
vanroeyrien
Reply 7 weeks ago
Thanks, although I have to wait for my package to arrive...
GlenB7
GlenB7
7 weeks ago
Where I'm from Live = Brown , Neutral = Blue. or an I missing something?
vanroeyrien
vanroeyrien
Reply 7 weeks ago
Sorry, you are correct. Thank you I've changed it in the instructable. Thanks for letting me know.
