Sound Glove JQ6500
Introduction: Sound Glove JQ6500
About: Maker and Cosplayer
Components:
micro button 12x12mm DTS 21N
crimp contact
Shrink tubing Glue - E6000 and super glue
Control cable - LIYCY 7X0.14
Control cable - LIYCY 6X0.14
Module - JQ6500
Output audio - JACK 3,5 stereo ST-3092
Terminal blocks - PTR AKZ700/2-5.08-V-GREEN
4x - 4 female header pins
Plastic box 43x33x22mm - KM1 ABS BLACK ST Circuit Board
Teacher Notes
Step 1: Circuit Scheme
Module - JQ6500
JQ6500 Mp3 Player Module Software: https://sparks.gogo.co.nz/jq6500/index.html
Step 2: Prepare Cable for Buttons
I used control cable - LIYCY 6X0.14
  1. Remove the rubber protection
  2. Divide the cable into data and ground
  3. Solder 5 wire to the ground
Step 3: Remove the Rubber Protection of Each Wire
Step 4: Buttons
  1. Stretch cord glued to the button
  2. Put crimp contacts to the buttons and bend it
Step 5: Solder the Wire to the Button
Step 6: Sew Stretchy Finger Sleeves and Glue It to the Buttons.
Glue: E6000
Step 7: Finishing the Glove
  1. Stretch cord carefully glued to the stretchy finger sleeves
  2. Painted to the black
Step 8: External 5V Power Supply
  2. Solder two-wire cable for external 5V power supply
  3. Solder other wires
Step 9: Dock
  1. Cut circuit Board
  2. Solder 8x terminal blocks
  3. Solder 4x4 female header pin
Step 10: Output Audio
Solder 3 wire and cover it with shrink tubing.
Step 11: Box
Abs plastic box 43x33x22mm
Drill two holes for cable and audio jack.
Step 12: Final Completion
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    audreyobscura
    audreyobscura
    2 months ago
    Awesome! You should enter this into a contest!
