Sound Traffic Light
Introduction: Sound Traffic Light
It is a traffic light that will make sound when the traffic light change. I use to connect with Arduino.
Teacher Notes
Step 1: Step1: What Should You Prepare
Arduino Uno
Breadboard
Switch
Resistors(3)
Connecting wires(11)
Red LED
Green LED
Yellow LED
Sounder
Step 2: Step 2: Improve the Features
My improved website: https://www.instructables.com/id/Arduino-Traffic-...
Before I change:
The Led change in green, yellow and red.
After I change:
Number of seconds per
Each light is changed, the first two second make sound
Step 3: Step3: Steps to Follow
Traffic light are use to make people know can they go? It use on the road and it is using to make people safe and walking without accident.
The traffic lights will give instructions to the drivers and pedestrians. From showing the standard color. The three colors generally used in traffic lights are Red, Yellow and Green.
This Arduino Traffic Light is make of connect each LED to digital pins ten, nine, eight. I add the traffic light with sound. The sounder is connect to pin three. When green light high, it will make the sound. When the yellow light shows, the green light lows; than it also making sound in first two second. It will be a cycle. The red light also shows, the yellow light low. It will also be sound in first two second.
Step 4: Step4: Run a Program
Programming code: https://create.arduino.cc/editor/Sophie1357/4662a...
void setup(){ // put your setup code here, to run once:
pinMode( 8 , OUTPUT); // sets the digital pin as output
pinMode( 9 , OUTPUT); // sets the digital pin as output
pinMode( 10 , OUTPUT); // sets the digital pin as output
void loop(){ // put your main code here, to run repeatedly:
digitalWrite( 8 , HIGH ); // sets the digital pin on/off
tone(3, 440, 2000); //改buzzer or speaker frequency
delay( 8000 ); // waits a few milliseconds
digitalWrite( 8 , LOW ); // sets the digital pin on/off
digitalWrite( 9 , HIGH ); // sets the digital pin on/off
delay( 4000 ); // waits a few milliseconds
digitalWrite( 9 , LOW ); // sets the digital pin on/off
digitalWrite( 10 , HIGH ); // sets the digital pin on/off
delay( 5000 ); // waits a few milliseconds
digitalWrite( 10 , LOW ); // sets the digital pin on/off
Step 5: Step4: the Sound Traffic Light
It is a video that shows the making progress, step and how it runs
please click here
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Warm and Fuzzy Challenge
    • Wearables Contest
      Wearables Contest
