Spanish Ring Knot Variation
235
4
Bruce Grant in :"How to Make Cowboy Horse Gear" presents the Spanish Ring Knot using a 5 bight, 3 lead TH as the base. In this variation I use the 4 bight 3 lead TH as the base.
I used gutted paracord (remove inside strands) so that the cord lies flat.
A dowel is needed
(fingers can be used once you are familiar with the process).
The clear glass marble (blue background shows through) will be used as luggage ID.
The other will be attached to a ceiling fan/light to eliminate a long stretch.
For the third example I tied the ring knot around a dime (small coin) and will use it as a lanyard.
Teacher Notes
Step 1:
Bring Working End (WE) around the dowel as shown.
Step 2:
Bring WE around the dowel.
Step 3:
Bring WE under one and over one strand.
Step 4:
Tug on the bight as shown and bring it over to the left.
Step 5:
This completes the 5B, 3L TH knot.
Step 6:
Bring WE under one and over one strand. Pull through.
Step 7:
Bring WE under two and over one - pull through.
Step 8:
Bring WE under two and over one. Pull through.
Step 9:
Bring WE under two and over two strands. Pull through.
Step 10:
Step 11:
Bring WE under two and over two and pull through.
Step 12:
Step 13:
Bring WE under two.
The knot is complete. .Tighten and trim ends.
Step 14:
Be the First to Share
    • Art Skills Challenge
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    2 Discussions
    asemery
    11 days ago
    It is not difficult. Use gutted paracord (inside strands removed) so that the cord lies flat.
    Use a dowel about the size of the marble.and tighten knot on the dowel
    Remove the dowel and insert the marble and start the tightening process.
    Do not try to remove all the slack in one attempt. Adjust the position of the marble as you tighten
    Penolopy Bulnick
    11 days ago
    I love how it looks with the marble in it! Is it hard to get it in there and tighten it all up?
