Introduction: Sparkling Cranberry Kombucha
Kombucha is an effervescent drink made with fermented black or green tea, sugar and a kombucha starter. It is known to have probiotic properties, and is said to have originated thousands of years ago in China. If you're concerned about sugar-intake, kombucha shouldn't be a problem for you-- the sugar in the recipe is consumed by the living kombucha starter, known as a SCOBY. This term is an acronym for Symbiotic Culture of Bacteria and Yeast. In addition, this probiotic yeast is called Saccharomyces boulardii, which is a good probiotic yeast; this strain of yeast is completely unrelated to the yeast Candida albicans and other Candida species.
Kombucha starters are easily obtained from an online source (I recommend www.culturedfoodlife.com) or from a friend or local source already making kombucha (you might check with a health food store or Craigslist to obtain a starter.)
It is extremely simple and economical to make Kombucha at home. My cranberry-flavored recipe produces a fizzy, thirst-quenching cranberry drink, similar to a sparkling cider or soda.
Ingredients
- 3 quarts water
- 5 black tea bags
- 1 cup Kombucha starter + 1 SCOBY (Obtain from someone local who makes kombucha--check Craigslist or health food store for sources; or order online at www.culturedfoodlife.com)
- 2/3 c. white sugar
- 12 oz. can frozen cranberry juice concentrate
- 4 quart or larger pot
- 1 gallon glass jar
- 2/3 cup measuring cup
- Large plastic spoon
- Paper coffee filters
- Large plastic bowl
- Funnel
- 6 dark flip-top bottles (Quart-size canning jars with lids can also be used; but the flip-top bottles are safer in that they are designed for the pressure of the fermentation, and the flip-top bottles produce the carbonation, while canning jars do not. Source listed below for Flip-top bottles.)
Step 1: Gather Ingredients and Basic Supplies
Ingredients
- 3 quarts water
- 5 black tea bags
- 1 cup Kombucha starter + 1 SCOBY (Obtain from someone local who makes kombucha--check Craigslist or health food store for sources; or order online at www.culturedfoodlife.com) Photo #3 is the starter/SCOBY
- Funnel
- 6 dark flip-top bottles (Quart-size canning jars with lids can also be used; but the flip-top bottles are safer in that they are designed for the pressure of the fermentation, and the flip-top bottles produce the carbonation, while canning jars do not. Source listed below for Flip-top bottles.) https://www.amazon.com/YEBODA-Amber-Glass-Bottles...
Step 2: Brew Tea
(I recommend that this step be done the night before, but it doesn't need to be.)
In large pot, heat 3 quarts of water to almost boiling.
Remove from heat; add 5 tea bags.
Let stand until cool.
(If you want to speed the process, ice may be added to cool the tea more quickly.)
Step 3: Make Kombucha
After the tea has cooled, place the 1 cup Kombucha starter and SCOBY (Photo #1) into one-gallon glass jar.
Add 2/3 cup white sugar. Stir well with plastic spoon.
Add 3 quarts black tea to jar.
Cover with coffee filter, and put the jar in a dark place to ferment for 4 days.
Step 4: Second Ferment
This step adds the flavor and fizz!
Pour all but the SCOBY and approximately one-cup of the kombucha into a large plastic bowl.
Add 1/3 of a can of frozen cranberry juice concentrate. Stir well with a plastic spoon.
Using a funnel, carefully pour the flavored kombucha into six flip-top bottles. Put lids on tightly; let sit on the countertop for 2 days.*
Then release gases and put finished bottles into the refrigerator.
*At this point, go ahead and start over with Step 1, using the reserved starter and SCOBY in the glass jar. In this way, you'll have a constant supply of kombucha every four days.
Step 5: Pour a Glass
Enjoy Sparkling Cranberry Kombucha over ice!
Step 6: Helpful Hints
- Other varieties of teas may be used, including green tea, white tea, hibiscus tea, rooibos, jasmine pearl. Herbal teas may not be used.
- Other sweeteners may also be used, including brown sugar, agave, sucanat, turbinado, honey, or molasses.
- As Kombucha is a living organism, individual outcomes will vary. For instance, the time required to ferment the kombucha is quite dependent on temperature. At 70-85 degrees, it should ferment in 4-8 days. At a cooler temperature, it may take longer. It may take some experimentation to determine the appropriate brew time for your situation. For troubleshooting information, I recommend the Cultured Food Life website, of which I have no affiliation.
Kitchen Skills Challenge
