Special FX: Almost-free Squirting Blood Effect
150,254
86
26
This instructable will show you how to make a Swiffer WetJet mop into a sweet squirting blood effect. Also included is a cheap way to make fake blood. Add on the optional circuitry, and you can get a pretty decent heartbeat effect to boot.
I will update this with more pics, when I make my second unit. (I mistakenly didn't take any while I made the first one.)
Step 1: The Supplies
Ingredients:
1 Swiffer WetJet - these tend to break pretty easily, so mine was free
1/4" Clear vinyl tubing - length is up to you
1 Hose clamp - as small as you can get
Something to put blood in
Fittings (If you need them for the blood container)
1 SPST switch
4 AA Batteries
Battery Holder (if you want to be fancy)
Optional:
555 Timer IC
5v regulator
potentiometers
capacitors
power transistor
(I'm not being specific on purpose. Read on for details.)
Tools:
Set of KEYED Torx wrenches - special tools that are great for lots of special jobs (See Picture)
Scissors or other cutting implement
Metal file - fine is better
Flat head screwdriver, or nut driver
Soldering Iron + Solder
Wire strippers
Step 2: Disassembly
This step will remain pretty blank until I make the second one. Just go slowly, and remove parts until you get something that looks like the picture. You will need special tools for this step - KEYED Torx wrenches of a couple different sizes.
WARNING: THERE ARE SOME VERY SHARP PIECES ATTACHED TO THE PUMP
Be careful, and use gloves if you value your fingers.
Step 3: Sharp Things
Once you get a motor/pump with some tubing and wires coming off, you are ready to begin assembly.
The intake is very sharp, and is essentially a really big hypodermic needle. Use the file to take off the point.
DON'T USE CUTTERS! - THEY WILL SMASH YOUR INTAKE CLOSED
Step 4: Intake Modification
Cut a piece of 1/4" tubing about a foot or so in length.
Cut a very small (approx. 1/4" length) piece of the tubing that came with the Swiffer WetJet.
Cram the small tubing into the 1/4" tubing - it should be a perfect fit
Modify the hose clamp - bend off the little tabs on the inside of the ring. This will make the hose clamp able to close even tighter, without chewing up your tubing.
Apply the hose clamp to the tubing, directly over the piece of small tubing. Tighten this until there is only the tiniest hole in the tubing.
Push the assembly onto your pump's metal intake. It will stay on without any problems. If you are paranoid, you can add tape. I'm not.
Step 5: Bag - O - Blood
If you've ever ordered a Bucket - O - Coffee from a coffee shop or even Chik Fil-A, You've got an awesome refillable blood container.
Drain any leftover coffee from the container.
Tear open the cardboard part as you see fit. Recycle to make some hippies happy. Reserve the heavy plastic (mylar if it's good quality) bag that once had coffee in it.
Rinse out the bag, and set it aside. Your focus is now on the cap.
Use your desired fittings (I went with fancy brass, but you don't have to) to make a cap that now has a 1/4" tube attached to it. The other end of this tube should be the one attached to the intake of the pump. (See previous step)
If you can track down some IV gear (saline bags, etc), you may find them better suited for this task.
Step 6: Electrisical Stuff: Part 1 - the Bare Minimum
To drive the motor for the pump, you need 6v @ 50mA (approx. Just do what the manufacturer already has set up - 4 AA batteries).
Set up a simple circuit with your switch, but don't test your pump just yet. It isn't necessarily bad for the motor to run a dry pump, but it's not something you really need to risk.
Use electrical tape or some other method to keep all electronics dry. Do this before adding anything to your blood sac.
Now that everything is ready, it is time to test for leaks. Fill your bag with plain water, and screw the cap back on. Check it for leaks, around the whole thing. Then, turn the bag upside down and check the cap's seal.
If everything looks ok, test your pump out. I was rather impressed with how much liquid it actually could move.
Step 7: Electrisical Stuff: Part 2 - Getting Fancy
If you are like me, and want to have the blood pulse to simulate a heartbeat, read on. Otherwise, just skip this step. I will get some pics up later on, but for now I'm going to assume that anyone willing to go further will know a little something about IC timer circuits.
Using the schematic, and solder of course, set up the timing circuit. Before adding it to the pump, have the circuit drive an LED. No need to get your fancy $2-3 timer investment fried for no reason.
What we are looking for is a small pulse with space between pulses. Use the potentiometers to adjust your pulse so it seems close. Remember that blood only travels one direction in a given blood vessel, so don't try to get that second "thump."
Waterproof your circuit as best you can, but maintain the ability to adjust the pulses. Depending on how long your effect tubing is, you will need to adjust the pulse duration.
Extra-Super-Mega-Fancy:
Use a microcontroller circuit, and make the effect as realistic as you like. If your situation calls for an on screen death, you may want to have the pulse length get a little shorter over time. You may also want to add a digital potentiometer or a separate connection with a resistor to end the sequence with a only a fine trickle escaping the fake wound.
Step 8: Blood Recipe
This recipe for blood is so simple, anybody can do it. It is specially formulated to be extremely visible when sprayed or pumped. It is safe to drink, and washes out of most clothing (I won't make any guarantees, just use items you don't really care about when using this effect.)
Off-brand Cherry punch mix - About $.10 a pack, and cases from warehouse stores make it even cheaper.
Water - I used 1 qt per pack of punch mix
Mix, and put it into your blood container. If you are lazy like me, just mix it in the container.
Bonus Points:
If you are going to have blood pooling, or moving slowly along skin, start with half the water and add:
Light corn syrup (No measuring. Keep adding until it is thick enough.)
A dash of chocolate syrup (For a little cloudiness)
If you don't feel like throwing away sweet things, you can use cornstarch or powdered gelatin. You're just going to end up cooking the blood until it gets where you want it.
Step 9: The Fun Part: Applying the Effect
Hide your blood container on the character's body somewhere. I chose to hang my bag off my back, underneath my shirt.
Run tubing discreetly, underneath clothing. Long sleeves are better for severed hands.
Use the sprayer for blade slashes - If the sprayer is in just the right spot, it will spray the attacker in the face.
Cover the end of the tubing with a makeup effect, or just hide it in your hand by palming.
NOTES:
This effect is a little harder to pull off as a stage/theatrical effect, since a gallon or so of fake blood will slosh around.
For cinema people, don't have dialogue in the scene unless it is absolutely necessary. The pump motor puts off a bit of noise. Wrap it in a washcloth to dampen sound, and put it in the character's pocket if you must have sound.
If you want an even bigger slash-type of spray, check back in a couple months for my next blood instructable.
Disclaimer:
I am not responsible for any actions taken by anybody who uses this instructable to do something stupid. This is intended for cinema special FX.
I took these pictures on a timer, by myself. They are only to illustrate the effect.
    • Paper Contest
      Paper Contest
    • Warm and Fuzzy Contest
    • Organization Contest
    26 Discussions
    Marth433
    8 years ago on Step 2
    Someone should take the sharp part and REALLY squirt blood on people.
    cvillewill
    11 years ago on Introduction
    The "blood" you used looks an awful lot like the stuff from Monty Python and the Holy Grail. Somewhere I heard that they used tomato soup...
    giarmecvillewill
    Could you be more specific with the fittings for the bag (sizes and where to purchase) and how you connect it to the intake of the pump. Is it possible to use the battery pack and switch that comes with the swiffer?
    Thanks
    Mike
    on one of the DVD extras, or maybe it was the commentary, i think it was maybe terry jones who said that they used this stuff called kensington gore, theres a bit about it on addikipedia
    that_one_guycvillewill
    Reply 11 years ago on Introduction
    I've heard that elsewhere, but I don't know whether it is true or not that they used tomato soup. Seems logical though. It may just be my camera + the lighting. I happen to know that my camera's autobalance tends to be on the red side - to help bring out flesh tones. It could also be because there is a lot of green in the frame. I would also suggest that filmmakers and theater people try to do these same things, no matter their particular blood formula. (create big contrasts that favor red, like using green or blue in the background)
    I just gotta ask, which coffee shops get liquid coffee in a bag, rather than in bean form? Other than Tim Horked-Ons,of course, who get their coffee by tanker truck, and store it underground, like gasoline. Perhaps they use old gasoline tanks, judging from the taste...
    The bag comes from the inside of a cardboard disposable coffee dispenser. I didn't want to pack around a bunch of cardboard, so I recycled it. They are also great for heating up water on camping trips for hand washing and showering. Solar Power!
    asianwizard
    10 years ago on Introduction
    am i able to fill this stuff with paint? and use it as an air brush?
    XHorntail
    If you put a 6v capacitor in series with the batteries/motor, you'll have a dealy after flipping the SPST, but after you toggle it back off, the stream will slowly die down. You could also toss in some solid state relays and use a sort of relay/capacitor ladder to get a burst effect, but that's a bit more expensive. For those who can't code their own controllers though, it'd suffice. Although, a potentiometer you hold in your hand would probably be easoer now that I think about it.. lol. anyways, great instructabe! never thought to salvage that for a pump, tons of uses, I'm sure!
    or -instead of using capacitors,-you could steal one of those flickering lights on the street when they're working on that street,and use the pulse generator.
    conn067
    A way of making fake blood that I've seen is mixing syrup with food colouring.
    Pull and Twist
    11 years ago on Step 9
    Good instructable... very detailed. I'll have to try this one out... never would have thought about salvaging a Swiffer WetJet for the pump.
    JWilly48519
    Film/video work in one take, with disposable costumes and disposable or waterproof props and set dressing, can use any blood formula. Theatrical work, and other contexts where you're going to do the effect more than once, need cleanability. A reasonably good theatrical blood formula is corn syrup, liquid dish detergent and food coloring as required. The corn syrup and detergent are both soluble in either cold or hot water, or dry cleaning fluid. The detergent helps to minimize binding between the dye and the fabric or other washable porous material it contacts. Definitely avoid things like chocolate milk, chocolate syrup or gelatin that contain proteins and thus can be set by the heat of a clothes dryer or iron, or sometimes by air-drying. Plus, they're difficult to dissolve with dry cleaning solvent.
    Simple problems have simple solutions. Wear darker colors - T-Shirts are best since they can be replaced Use as little fabric as possible - a probable reason for slasher films being kinda racy Tide Pen - it's your friend, and when kool-aid blood is in small quantities, you would never even know it was there 10 minutes later.
    wow cool. I wont be building this (no reason to, I dont even have a video camera) but I now know where to find a small water pump which I've been wanting for a long time...
    Chris Bilton
    will the fun never end!! it's worth the ruined cream coloured carpet for the look on their faces...whoops, I should have done it outside...
    MadMechanicMike
    11 years ago on Step 1
    haha i just happen to have an old swiffer laying around. seriously. lol ive been looking for something that can do this for one of my movies. i never thought of a swiffer, sweet thanks.
