Spider Capo
Introduction: Spider Capo
Spider Capos are very interesting musical tools that allow the user to capo individual strings on a guitar. All you need to create one of your own is a CAD program and a 3D printer (with filament, of course). This assembly is made up of 9 distinct, easy-to-design parts; The rod, the 2 end pieces, the 4 (or 6, see Step 3) pegs, and the 3 spacers. The way this assembly is designed, it can be used on either a guitar or a bass guitar. I printed mine for a bass guitar, but there is very little difference between the build for a bass and the build for a regular guitar. Sizes generally don't matter, as long as they stay consistent throughout the design process. The last thing to mention is that there is a locking system, made with drafted rectangles and spacers. This is a very fun build with a great result!
Teacher Notes
Step 1: Main Rod
The first step in the Spider Capo assembly is the Main Rod. Everything is built around the main rod. Sizes are subjective in this assembly, but this specific build is 3 inches long, 1 inch wide, and 1 inch tall. There is an extruded corrugated pattern on the sides, which allows the rod to fit in to the Endpieces (Step 2). Once you make the rectangle, cut a 0.5 x 2.5 hole through the rod and corrugate the insides with the cut tool, as seen in the picture. You will also need a small slit to account for the rod spacer (Step 4). Once you finish the insides, corrugate the outsides as you see fit. Then your capo rod is finished.
Step 2: Endpieces
The next step is the endpieces. The endpieces grip the sides of the neck of the guitar and lock the rod into place. Make a rectangle of any size, and extrude it to roughly 0.75 inches. Then cut out a hole in the middle that is the width and height of the rod. Then make room for a spacer. The shape doesn't matter, as long as the spacer slides in and out easily. Then cut out corrugation on the opposite side of the spacer. Then make at least one bar for the endpiece to rest on the neck of the guitar (one on the bottom is optional, but not necessary). Finally, make another endpiece with the corrugation and spacer on different sides that they are on in the first endpiece.
Step 3: Pegs
Step 3 is the pegs. The pegs are very simple, but very important. They actually press down the strings to do the actual capo-ing. The only necessities of the pegs are that they must be a little bit taller than the rod, and they must have one bar of the corrugation. The rest is up to the ol' imagination. Personally, I made the top chamfered into a pointed top to help with grip, and I left a small indention on the bottom so the string doesn't slide out from under the peg, but these are not necessary. Since this build can be used for any amount of strings, just print as many as you need (4 for bass, 6 for standard guitar).
Step 4: Spacers
Step 4 is the spacers. The spacers are also very simple and very important. They lock the corrugation into itself to, essentially, allow them to work. Again, most of this is up to the imagination, but it depends entirely on the space it has been left. The rod spacer (which holds the pegs in place) is just a flat, skinny piece the length of the cut in the middle, and the thickness of the rod space minus the thickness of the peg. The endpiece spacer is different, and more up to the imagination. The only requirement is that it needs to fit in the space you left, and it needs to lock the rod into the endpiece.
Step 5: Assembly
Congratulations! You made your own spider capo! Now, why are you still reading this? Go jam!
Be the First to Share
    • Toys and Games Challenge
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    6 Discussions
    GeorgeS368
    GeorgeS368
    1 year ago on Step 4
    Krok 4 to Elementy dystansowe (przekładki).
    Elementy dystansowe są również bardzo proste ale bardzo ważne. Blokują one
    powierzchni karbowane, uniemożliwiając im wzajemne przesuwanie się. Jak wyżej i
    tu, dokładny kształt zależy od wyobraźni, ale też zależy całkowicie od
    przestrzeni, która pozostała.
    Element dystansowy korpusu
    (który utrzymuje kołki na miejscu) jest po prostu płaskim, cienkim długim kawałkiem,
    wyciętym w środku o grubości szczeliny dystansowej Korpusu głównego minus grubość Kołka.
    Końcówka Elementu dystansowego może
    być inna i bardziej zależy od wyobraźni. Jedynym wymaganiem jest to, że musi
    zmieścić się w szczelinie, którą zostawiłeś, i musi blokować Korpus główny w Elementach końcowych
    GeorgeS368
    GeorgeS368
    1 year ago on Step 3
    Krok 3 to kołki. Kołki są bardzo proste, ale bardzo
    ważne. To one naciskają struny, przed ustawionym progiem gitary. Jedyną koniecznością
    dotyczącą kołków jest to, że muszą one być nieco dłuższe od Korpusu głównego i muszą mieć jedną stronę
    pokarbowaną. Reszta zależy od twojej wyobraźni. Osobiście zrobiłem górną końcówkę
    jako spiczasty wierzchołek, aby ją było łatwiej uchwycić i zrobiłem małe zagłębienie
    na spodzie, po to by struna nie wysunęła się spod kołka, ale nie jest ono
    konieczne. Ponieważ ta konstrukcja może być użyta dla dowolnej ilości strun, możesz
    zrobić tyle kołków, ile potrzebujesz (4 dla basu, 6 dla standardowej gitary).
    GeorgeS368
    GeorgeS368
    Następnym krokiem są Elementy końcowe. Elementy te chwytają
    boki szyjki gitary i utrzymują na miejscu Korpus
    główny
    . Utwórz prostokąt o dowolnym rozmiarze i wyciągnij go do około 18 mm.
    Następnie wytnij otwór w środku, o szerokości i wysokości Korpusu głównego. Następnie zrób szczeliny na elementy dystansowe.
    Kształt nie ma znaczenia, chodzi o to, by element dystansowy łatwo się wsuwał i
    wysuwał.
    Następnie wytnij (uformuj)
    pofałdowania po przeciwnej stronie elementu dystansowego. Następnie wykonaj na
    środku Elementu końcowego jeden prostokątny
    opór, aby końcówkę można było zamocować na szyjce gitary (drugi skośny na dole
    jest opcjonalny, ale nie jest konieczny). Na koniec wykonaj drugi Element końcowy, ukształtowany w
    zwierciadlanym odbiciu w stosunku do pierwszego.
    GeorgeS368
    GeorgeS368
    1 year ago on Step 2
    Pierwszym krokiem w budowie
    Spider Capo jest Korpus główny.
    Wszystko jest zbudowane na bazie Korpusu
    głównego
    . Rozmiary są subiektywne w tym zestawie, ale ten konkretny korpus
    ma 75 mm długości, 25 mm szerokości i 25 mm wysokości. Po bokach wytłoczony jest
    pokarbowany wzór, który pozwala korpusowi dopasować się do Elementów końcowych (patrz krok 2). Po wykonaniu prostopadłościanu
    musisz wyciąć otwór 12,5 x 50 mm przez korpus i ukształtować wnętrze za pomocą
    narzędzia do cięcia, jak pokazano na rysunku. Będziesz także potrzebował małej
    szczeliny, dla elementów dystansowych korpusu (krok 4). Gdy skończysz wnętrze,
    pokarbuj stronę zewnętrzną, tak jak uważasz to za stosowne. Teraz twój Korpus główny capo jest skończony.
    GeorgeS368
    GeorgeS368
    1 year ago on Introduction
    Cały zestaw składa się z 9 różnych, łatwych do
    zaprojektowania części: Korpus główny,
    2 Elementy końcowe, 4 Kołki (lub 6, patrz krok 3) i 3 Elementy dystansowe. Zestaw ten jest
    zaprojektowany w tak sposób, że może być on używany zarówno na gitarze
    klasycznej lub gitarze basowej. Swój wydrukowałem na gitarę basową, ale różnica
    między budową gitary basowej a budową gitary klasycznej jest bardzo niewielka.
    Rozmiary na ogół nie mają znaczenia, o ile pozostają spójne w całym procesie
    projektowania.
    Ostatnią rzeczą, o której warto wspomnieć, jest
    to, że istnieje tu system blokowania, wykonany z pokratkowanych prostokątów i
    elementów dystansowych. Jest to bardzo ciekawy pomysł dający niezły efekt !
