Introduction: Spider Man Watch !!!
Hi!!
We all are here to make and discover new things in the all around Instrucable contest . we all are doing our best in creativity .
Now, me and my friend are here to make a instructable named Spider man watch !!
It's very very simple to make and also you can gift it to all your friends .
so lets get started and make Spider man watch !!!!!
  • piece of cardboard
  • sketch pen
  • paint (red and black)
  • paint brush
  • spring (3 cm max)
  • pair of scessor
  • glue
Step 1: Cutting a Sketch Pen .
First take a sketch pen and cut it from bottom (3 cm) .
and remove the bottom cap from it so we can fix spring in it.
Step 2: Cutting the Cardboard
Now keep the sketch pen aside and take a peace of cardboard and cut it into a square shape (3cm).
cut two piece like this and then take another cardboard and cut the rectangular shape (3 cm and 1 cm)
Step 3: Making the Main Part of Watch
Now take the cutted cardboard and stick it same shown above .
Stick it properly from the corner so it looks good as such.
Take care :- when you are applying glue on cardboard it will soak it can damage your cardboard .
for this thing apply little bit of glue on your cardboard.
Now,take the sketch pen part and stick it inside the box you have made .
and before this take spring and insert it inside the sketch pen part .
Take care :- you can get hurt so put the spring slowly .
Step 4: Wrist Strap
Now again take a cardboard strap and cut it 3 cm broad and the length (measurement of your hand) .
Step 5: Position of Watch to Stick on Strap
When ever you stick the upper part of the watch take care it should be in middle .
now take a scale and measure the length and mark it from between (like if its 10 cm then 5 cm, if 20 cm then 10 cm).
If you have marked it then stick the box on it carefully .
Step 6: Finally Painting !!!
Now, if you have made the watch color it with paint red .
Then let it dry and draw lines or any other design on the strap . Will look good.
now if the box has got dry make a spider tag on it .
And now its readyyyy !!!!
