Spoilboard Pattern
144
Introduction: Spoilboard Pattern
How to resurface, and add a grid pattern to your spoilboard.
Teacher Notes
Step 1: Resurfacing
Add some paint or lacquer, so that you can verify that material has been removed from the entire surface.
Do not run this without a dustshoe ! It is very very dusty,... I learned.
Step 2: Engrave Pattern
Step 3: Paint Pattern
Step 4: Sanding
Step 5: Customize
To create your own grid:
1) download the .txt file, rename it to .scad and open it in OpenScad
2) Enter the size you want, and line thickness.
3) Press F6 and export as .dxf
4) Open in f-engrave and set the height to the same value as in OpenScad
5) Export gcode and engrave
Note: f-engrave is not super happy about a square grid, so you can divide it in three files for vertical, horizontal and circles.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    4 Discussions
    kschoenrock
    kschoenrock
    Question 15 days ago on Step 4
    Would you be willing to share the file?
    KronBjorn
    KronBjorn
    Answer 14 days ago
    Yes, of course, I just need to clean up the OpenScad file a bit. Then I'll put it online.
    Thx for the interest.
    kschoenrock
    kschoenrock
    Reply 14 days ago
    Thank you so much. that is just an awesome, and elegant idea!
    KronBjorn
    KronBjorn
    Reply 14 days ago
    np, I have added the OpenScad file.
