Spport for a Friend - Engraving
The idea was to support a friend by giving a self-made engraved plate as a reminder.
Supplies:
- left over mdf wood (thickness doesn't matter)
- a design that is engravable (black/white)
Teacher Notes
Step 1: Prepare the Picture for Engraving
In attachment the svg file.
Make sure the colors used are only black and white, you can edit this in inkscape, and if needed you can trace bitmap and define the threshold of black and white
The extra red lines in the drawing are to mask out the imperfections
Step 2: Load the Lasers!
Set the (scrap) wood in the laser and let it burn!
For a better result, it might help to run the same engraving a few times over the same surface, then it burns off more wood and the engraving becomes darker.
If required, you can edit some part of the picture so you create a sort of relief planing.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
