Sreeching Owl Bird House
For bird lovers that want more with there, bird viewing need here's a house to attract a special kinda owl.
Supplies:
power equipment ( drills,saw est. )
10X95in wood plank
1inx12in wood plank
half in wood screws
wood glue
Teacher Notes
Step 1: Cuts
Messer out 15 in slabs and make 4 pallets and use a saw to cut them and make sure they are all even
With the extra woodcut a 10X10 slab for the bottom
Then the last of the wood will be used later on for the top
Step 2: The Door
You will need to cut a 1 3/4in cut long ways on your pice that you want the door
Make a half-circle that is 4 in diameter on the pice that you want as the front
Make sure everything fit the way you want it to then move on to the next step
Step 3: The Groves and Stands
on the back or inside side of the door make groves that start at the bottom of the door to the top that is one inch apart.
Next cut two planks the size of the door from the 1x12 piece of wood and put a least one an inch from the bottom and an inch from the bottom of the hole you cut out
Drill plat holes two in each piece of wood (use a bit the is smaller the screws groves)
The use the screws and drill them in tight
Step 4: Walls and Bottom
Drill all the side together except for the front (DO NOT DRILL FRONT ON YET)
LIne everything up and drill pilot holes just like we did for the front and drill one at each ends/corners and the middle for extra security
do the same with the bottom just three nails in the middle of each side
Step 5: Point for Door
For the door finding where the pivot point is so testing where the point is the never moves from the same place when you oping the door from the bottom( for us it was 2 in down)
next drill just like you did with the sides ( you might not want to do as tight so it is easier to open the door)
Step 6: The Roof
Take a 10x10 in wood slab and cut out the half from a corner to the other corner
Place in the each of the sides with wood glue to hold it in place and wait for it to dry
Then take a nail gun a pin it down at the back easy and that the front put it at and angle of 90 degrees and shoot it an pin it down at the front
final nail gun the top down and put more nails in it for more security
Step 7: Weather Proof It
Put any weatherproofing spray on there just to keep it intact longer outside
DO NOT PUT ANY INSIDE
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
