Stabilo "s Move" Refill Fix
4,746
Introduction: Stabilo "s Move" Refill Fix
the ergonomic s move is a great pen, it fit sthe hand lovely.
It's a shame that the actual roller ball pen is so bad.
So this is how to fit a Bic Fine line (a personal favourite) instead.
Step 1: It's a Nice Pen But
this is the ergonomic stabilo "s move" it comes in a specific left hand and right hand configuration.
It's very comfortable....but
Step 2: The Rotten Refill
good gravy who picked that as the refill?
It's a really primitve rollerball.
And to make matters worse, this one is blue!
Step 3: Make a New Refill From a Bic Fineline
It is nothing to look at but the Bic fine line does a really good variety of strokes.
I'am a professional artist and despite the number of pens I use, one of these blighters is never out of my hand.
But it's way too long to fit here.
Junior Hacksaw please.
Step 4: Sawn Off
pop the lid, take out the refill and the black plastic bung at the other end.
Now measure back from the front 31.5mm and saw the blighter off.
Step 5: How Much Ink Can You Fit on the Head of a Pin?
now all ballpoints have the little gap between the level of the ink and the end of the tube.
So scoop out some with a pinhead.
I do not know why but when I didn't do this there was ink all over the place.
could be surface tension,air pressure or room for heat expansion I can not say.
Step 6: Bung It Back In
This black plastic bung needs a bit of filing to fit as the shortened barrel is a little narrower.
it's pretty much trial and error.
And if you split the barrel then just super glue the thing together.
Step 7: Pop It All Together
put the shortened barrel and refill together
Step 8: Nearly Done
then pop the mini Bic back into the stabilo and put it back together
Step 9: And There You Go
there you have a stabilo s move with a custom cut refill tube into which you need only snip down any bic ball in to fit.
I know it isn't very complex but I am only really posting this as I was doing this on the day I found instructables.
It seemed appropriate.
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Metalworking Contest
    • Maps Challenge
      Maps Challenge
    4 Discussions
    canida
    canida
    13 years ago on Introduction
    Hello, and welcome to the Instructables community!
    This currently does not meet our criteria for an Instructable. A completed Instructable:
    - details a finished project with instruction (not just links to instructions)
    - has clear images that you took of your project (web-found clip-art is not acceptable)
    - uses proper spelling and grammar
    - contains appropriate cautions or safety considerations
    - does not violate someone else's copyright
    - does not violate the Instructables terms of service
    - is typically written about something you are very passionate about and want to share.
    If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums.
    Look here: https://www.instructables.com/id/ELHMNOA69REUF10WM7/ for tips on writing a great Instructable.
    So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
    error404
    error404
    Reply 13 years ago on Introduction
    Ok, I am slightly mystified by this. so point by point. it is a wee project I have just done all the pics I took is properly spelled and the grammar, to my thinking, is fine. it requires no safety announcements violates no copy right does not violate the terms of service and as I have been very passionate about pens, I am a preffessional artist, I think it is safe to say that it breaks no rule there. If you can tell me where I have erred from your list I will be amazed. YoursSincerely error404
    canida
    canida
    Hi error404,
    You're right, my standard boilerplate doesn't quite cover this. Your instructions are embedded in the pictures, which makes it quite hard for someone to read and understand the instructions- instead you should make better use of the step-by-step format and pair pictures with text (and photonotes) for each step. You'll probably only need a couple of steps, but frontloading them all into the intro is problematic.
    Just spread your instructions out, add or duplicate the information in accompanying text, and it'll be fine.
    You're welcome to drop me a note *before* republishing if you'd like these comments deleted before it goes up.
    error404
    error404
    Ah righto, cheers Canida, I shal;l look into reeciting the blighter. Didn't mean to cause any problems. Cheers Pol
