Introduction: Stag Deer Head Drawing Pin Art
I'm a mountain loving kind of chap and had the idea to create a deer drawing pin art project a few years ago. I finally got round to making it and thought I'd share the results. You can buy a whole bunch of drawing pins on eBay for around £5.00, so its a fairly cheap project to do too.
What you'll need:
Step by step:
What you'll need:
- Sheet of 8mm MDF wood
- 3 metres of 2"x3" wood
- Screws, saw, drill, wood glue, hammer and screwdriver
- Roll sheet of cork (got mine from a model railway shop)
- Cork spray glue (for floor tiles)
- Tub of wall emulsion and paint brush
- A projector
- Stag Deer outline template (attached below)
- 1000+ silver drawing pins
- Patience...
Step by step:
- Cut the MDF to your desired size
- Cut the 2"x3" wood into mitre join (45 degree angle) strips to fit on the back of the MDF panel
- Glue the wood strips onto the back of the MDF, drill pilot holes and fix into place
- Paint the sides of the panel with the white emulsion (several coats needed)
- Roll out the cork and glue into place with the floor tile spray glue
- Cut off excess cork along the edges for a nice finish
- Use a projector to project the Stag Deer Template zip file below
- Start pressing in the drawing pins into place in the black area of the template and gently fix into place using a hammer
3rd Annual Make It Stick Contest
