Stage by Stage 2x72 Belt Grinder Plans
Introduction: Stage by Stage 2x72 Belt Grinder Plans
About: I started his professional life as a kitchen and cooking supervisor in La Meridian and served there with a reputation. Later, I was promoted and delivered the responsibility to develop hospitality and health...
Yet, we used 4 x 36 size grinder for making DIY tools, we have waited a lot to get a 2.72 belt grinder. After doing some design research, we came out with a decision that we can make one by our self. We already have all the tools & chunks at our scrap bin plus I took suggestions from the internet.
This article is about our first 2x72 belt grinder plans & how we do it. Let’s start!
Teacher Notes
Step 1: Constructing the Body
Spot the Metal this way shown in the image.
Furthermore, weld each piece of metal in 13 inches in length Square tubing 2X2 and 4mm thick shape for the future placement.
Furthermore, weld each piece of metal in 13 inches in length Square tubing 2X2 and 4mm thick shape for future placement.
Step 2: Construct the Basement and Stand
After welding the full body of each individual metal piece, it is time to do some drill gaps and spot the entire thing on a thick base Wood for this situation.
Step 3: Manage the Holder and Shafts
To protect and control the metal pieces
that we used to make the body we have to make holder & shafts. Drill gaps over the metal by utilizing a big bolt.
Weld it set up and afterward we will almost place these holders & shafts that hold the complete set of metal tube ensuring everything is in perfect place without any motions or vibrations.
Step 4: Set Up the Tracking Wheel
Over the top of the 17-inch metal piece set
up a tilting Tracking wheel holder. Utilize a 4 inch Square tubing to set the shell in an angle direction.
Dig two holes on both sides. Dig a bigger hole in front & keep another one little bit small. Remember, the big hole is the place where the Wheel will set up.
Ensure that the entire thing is secured by utilizing locking bolts.
Ensure it goes all over down & up.
Step 5: Handles
To design & construct the handles we utilize a 4 inch long bit of metal and after that welded a big nut to it. Slice it to get a perfect size and crush it.
Moreover, you can add a slice touch of Black paint and presto. Keep in mind that you will require 3 handles to make your 2x72 belt grinder.
Step 6: Materials
Besides these I demonstrated above, we also
require some other additional tools & materials. Such as,
  • Five Square tubing pieces each in 2X2 Inches and 4 mm thick; three is 13 inches in length, one is 5 inches and other is 14 inches in length,
  • Three Square tubing pieces each in 1X2 Inches and 2 mm thick in size,
  • A 200 mm processor motor With an 8 Inch Wheel,
  • What's more, a flat metal which are 3 inches wide by 5mm thick and 8 inches in length,
  • 2X72 Inches actual belt
  • And a layer of paint.
Now you got everything that you need. So proceed to build something new.
Step 7: Safety Gear
Don’t forget to use safety gear & tools while you are working on it. This is exactly you need to keep near yourself.
Step 8: The Final Stage
Now we are all in the final stage. Combine every stage I demonstrated above & built a new 2x72 belt grinder.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
